  • Replies 57
Godzilla Motorsport cars will be out in force...
The little black duck (Mark Jacobsen)
Twoogle (Paul Diemar)
RH9 (John Alphabet)
R34 GTR (Willo)
The Red Rocket (Tony Wedlock)
VL JWauto (Justin Wilkinson)
and a few other customer cars...
hope we all go well...good luck to the other competitors.
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4727136
RH9 (John Alphabet)
R34 GTR (Willo)
awesome.
can't wait for jambo just like every year.
will be a cracker! :D
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4730115
What kind of license do you need to race at jambo? i'm guessing it depends what category you fit into? I'd love to enter this year but the 32 is gonna be a run in stage and i'd get murdered if I decided to do full power run's on a 500km old engine.
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4732157
Civil licence is enough depending on how fast you plan to go...11's require a super street licence and anything faster requires a full drag licence.
500K's is heaps mate...i ran 9's on my engine with about that on it. Modern piston and ring technology is far superior than the days of huge run-ins and babying for 1000's of k's is long gone.
Jason there may be an oportunity to test prior at a private hire im attending...ill let you know if its possible for you to come.
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4733142
Birrong Automotive will be there with OOH-30T.
Alex, you just say the word and we'll put the new car in the studio. Raf's Supra comes out in a couple of issues time.
I may be racing a 700hp GTST but no guarantees. At the very least I'll be there for work.
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4734361
I'll Be coming down this year finally with a fellow rotor head. Can't wait to see it all. So glad they now allow 6cyl's to the event !!!!
Will look out for Twoogle, been keen to have a gander at your car paul. Also like to check out your car Adrian if your able to bring it !
Gary
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4751283
Thanks Adrian almost done, can't wait! :)
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4755365
Gary
Cheers Gary...will see you there.
Booked flights today to come up for a test session on the 19th to get the car dialed in. Big thanks to Dazmo who will be giving me some transport and crewing for me that day. Hope i can reward him by running some good numbers.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4755535
Won't be there with my car but would like to share some accomadation - car all that stuff with some one making the trip. Coming from WA . please let me know who's doing what - see if we can sort something out.
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4757223
Im staying in Brisbane, usually stay at Skyline Court Apartments. Close to the Valley for night time action. Ill have my Jeep for transport etc, when are you flying in ?
https://www.sau.com.au/forums/topic/279948-jamboree/#findComment-4758562
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
