On the Friday - whats Skyline apartments number as i will see if i can get a room?
Im staying in Brisbane, usually stay at Skyline Court Apartments. Close to the Valley for night time action. Ill have my Jeep for transport etc, when are you flying in ?
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4760079
  • Replies 57
They have vacancies i was talking to them today, i might be able to pick you up from the airport if im finished prepping the car when you fly in. Otherwise its not far to get a cab from the airport to SCA...about $28 from memory.
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4760136
Yes your right i too have contacted them today , when are you ariving as i can help prep the car if you like as i will come a day or so earlier if that suits, all sounds good to me - share / sepperate -whats your thoughts?
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4760152
Yeah ill be racing in (i think its called) sport compact or something! First time at the drags in a couple of years!! Getting excited now!
Kyle Vance...you are racing in Street Compact...see you there and good luck.
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4772248
Congratulations to Paul DirtGarage he ran a pb last night of 9.54 @ 126mph (with a little bit of help from some inpromptu dazmo engineering). Still should have plenty more in it yet so bring on the jamboree Good luck mate.
the trailer plug was the pivotal link to assure the car would run a number. Thanks for your assistance yesterday getting the car transported to the track.
Big thanks to Mark Jacobsen for helping get the car sorted for the meet next week.
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4778506
The good bit is knowing how much is left in it when itty bitty dirt man learns how to change gears. :D
Grats paul. Tuff tuff car man. :cool:
still cant change gears and still ran 9.6 at a shitty 127 MPH. the car in the other lane ran 9.6 @ 148...a good run will see a low 9 from those stats...im pissing off the c's short shitfter and putting a stocker in it as they apparantly are no good in dogboxes.
ran a new 60' PB of 1.371
see what happens tomm. eh
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4795959
Yeah bring it hard tomorrow paul, The car is launching like a bullet, I can only imagine how pissed orf you are when we hear you hunting for cogs.
G/l man, We'll be there pullin for ya. :cool:
I watched a vid of the earlier 9.7 run and it torched the tyres hard (1.6 60'). The tyres were green as they were brand newies swapped from the front but now they have been scrubbed up the 1.3's are back.
did you see the 9.6? some of the guys saw sparks flying out from under the car in the deep end as i was battling the box.
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4796003
Yeah I saw the run but I couldnt see what was doin in the deep. I was camo'd against the wall of the corporate box and you cant see over the hump from there. Good luck today bud. :cool:
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4796201
Fixed the shifting problem...dogboxes do not like c's short shifters. Thanks to Paul Ruzic for tracking me down a stock shifter at 9.30 last night and Rajon for opening his shop at 7.30 this morning so i could pick it up...top stuff guys.
Ran a new PB of 9.45 @ 142.7 with also a new 60' PB of 1.36
in the afternoon with more boost on board ran 9.7 @ 144 but turned the tyres right through 1st gear hurting the ET.
Congrats to Mark Jacobsen on winning the class and running a new PB of 7.7 in the semi final.
Big thanks to the Godzilla team for their help with the car.
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4797115
congrats looks lik i mite have to change to a stock shifter also...
the difference is incredible...gone from a notchy box that wont shift at high rpm to something that is so smooth that you can shift with confidence. Now ive got to learn to stop using the clutch to pick up a few 10ths to get it running 9 flat.
https://www.sau.com.au/forums/topic/279948-jamboree/page/2/#findComment-4797156
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
