my r33 is making a popping sound when i am on full boost and it seems to only happen on full accelerator
it sounds very worrying , it is like vrrr ssshhh pop pop pop sorry i dont know how to explain it better
any thoughts would be appreciated
https://www.sau.com.au/forums/topic/279972-popping-sound/
does yours happen under heavy acceleration at about 5-6000rpm on full boost??
That points towards the coilpacks if its happening above 5000rpms, but yeah, regapping your plugs and giving the afm a clean wont hurt
https://www.sau.com.au/forums/topic/279972-popping-sound/#findComment-4725312
after you done/tryed all thats mentioned by other peeps go buy some AFM cleaner and clean up your AFM, it all helps
+1 i bought some contact cleaner for afm from autobarn @ 20bux and game my afms a clean and the car seems to idle better and feel smoother in the rev range; although it probably aint the problem, i now think its a must as afms seem to get dirty quite quickly.
https://www.sau.com.au/forums/topic/279972-popping-sound/#findComment-4726244
i seem to be geting this problem aswell, although my s1 r33 seems to spitt out white moke after backing off aswell. havent changed anything yet, coils,plugs probly, could a buggerd turbo be causing all the white smoke??
white smoke = oil
black smoke = fuel
white smoke probably means you've got a dodgy oil seal somewhere in the engine, either piston rings, or turbo.
https://www.sau.com.au/forums/topic/279972-popping-sound/#findComment-4729072
