I took out my white speedometer kit, in my 94 R33 NA, and after putting it all back together the speedometer doesn't show up the right speed. IT shows up roughly half the speed i'm doing. So when i'm doing 80 it shows roughly 40. The car is running fine, and i don't have a problem with the taco. Any ideas?
kor
https://www.sau.com.au/forums/topic/280263-speedometer-problem/
My mate took the cluster out of his Toyota and removed the plastic front, put it back in then followed me at 60 according to my speedo. He held the speed, pushed the needle back on at 60 and replaced the plastic front. Been correct ever since.
ahhh quality mechanical work, there's just nothing finer for your 87 camry
Haha see the reason i asked was because i just had my car converted from auto to manual and the automatic cluster reads only half the speed. pretty much exact same problem but different.
I have heard that there is a way to re-calibrate it from the back of the cluster but I'm unsure on how this is done, should probably search it up im sure its been covered at some point. One thing you can try is unplugging the cluster, starting the car, then plugging it back in while its running. This seemed to do the trick with my old tx3 turbo, but i cant guarantee anything.
there is a tutorial on adjusting the cluster on this forum somewhere. it is done by soldering up jumpers on the back of the speedo.
also if you converted the car from auto to manual and didn't change the diff then it will read out as well because the auto diff ratio is different and the speedo reads from the gearbox.
Yeah i had the cluster changed to manual and yes its still running auto diff, i prefer the higher gearing to manual one. Its only out by 3km/h at 60, and 5km/h at 100 (reads lower). Ive checked it out with a couple different gps units. With 18's on it reads perfect again so no problems there for me :D
Edited by SkyHi_33
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
