  • Replies 304
  • 4 weeks later...
Thats probably as gutted as i wanna go with the doors, as without the cross brace the top flexed inwards. Top alloy mount is for the Lexan/poly carb windows. Pedal box is all mounted and braced, made up a custom plate for the trans tunnel to mount the G-sensor and Hydro handbrake on. Also had to mount/ drill holes for the Craft square mirrors as they arnt made for a 4dr. Also bent up some tubing for a high wing stand. Getting some steel laser cut this week, then weld that in.
Over the next week, getting some cooler piping finished off and all underneath seam welded and holes welded up.
  • 3 weeks later...
Yup, 295/30/18 all round on a 10.5 should be fine :)
Thats the main reason for going wide body.
hey
i have been following this build very impressive im getting scared lol
anyway i have a set of 18x11 te37sl with 295 rubber if u wana trial fit to see how they sit on your awesome build
If you are going wide body then why not go with a 11.5" wide rim so you can run 315 rubber, that gives you a lot of tyre options. I am getting a set of BBS E88 in 18x11.5 now if you are interested PM me.
How much you looking at for 315 tyres? already with 295/30/18 there around $670 each.
No one makes wide carbon front guards either :(
No but there are plenty of good metal work places that could modify some standard guards.
Looking on Tirerack about $350-$500/
PM me if you want to know more about the BBS E88's, they are a motorsport wheel and lighter than a standard set of LM's.
Great work Luke.
Mike, who do you recommend for metal work? I wouldn't mind fitting the 18x11 +18 into my honda s2000....just need to find a good place to stretch the metal out a bit... a fair bit actually since the OEM offset is like +60 haha
Great work Luke.
Give me a call tomorrow man, anytime is fine.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
