  • Replies 340
Posted Images
Nah I didnt think of that, Im trying to clear up my loan as fast as possible, once thats done it will free up a heap of funds, So i may delay the cage for a while and run the car in supersprints / track days While I learn to drive the thing properly before I start doing door to door stuff,
Last think I would want is to wreak sombody elses car off, because of a silly mistake or somthing.
In other news I have the car at my house now, and I even gave it a wash, Just gotta wait for my de-cat pipe to turn up so I can fit the exhaust up, and not piss the neighbours off with a straight exhaust lol.
Question re: Bonnet pins, If I have no bonnet latch do i need to run 2 sets of pins or does 1 pair count as 2 bonnet restraints?
my reading of the bonnet pins was that if the car is road registered.. and has the normal bonnet latch.. it must have pins as a secondary catch... but if its unregistered.. then it only needs pins.. but thats just my interpretation of it.
have you checkd a price with riskgin?
seriouslt if you cant afford acage you cant' afford to race
by that do you mean a full on welded in jobby... or do you count a bolt in as a cage aswell or does a bolt in cage not count?? only ask coz im planning on using a bolt in.. the cages thing.. it confuses me.
A bolt in is easy enough for me (circa $1k), but a weld in is generally twice the price or more going off the quotes ive had.
Plus Im saving for a decent daily that can tow, so things will slow down on this build front for a while.
I'm sure Duncan will agree.
Don't go with a bolt in cage, save your money and do it once properly. I actually owe my life to a bolt in cage from some 10 years or so ago but I'd never recommend one for circuit racing.
I'f you know what you want pm me and I'll give you a quote to do a proper cage.
yeah look the difference between a bolt in and full on weld in is about $1k (esp if you get brad to do it).
It is a permanent investment in that shell and apart from safety will tie the car together much better.
Considering a single set of semi slicks or slicks are $2k+ a weld in cage is good value
It needs to be tuned, and im still trying to decide whether to have this one tuned or just wait for the RB30.
I may still run the 25 but wont be done before the SAU day, Too much to do and I dont wanna rush things to get it all done.
Edit, Also needs a new timing belt
Edited by zebra
Yeh exactly. Dont go rushing stuff. Will only end in regrets later on. Take your time and do it proper! :)
Thats the plan im sticking to with my project. I must admit it does get tempting to just go hard out and dodge it up to finish it quickly.
What sort of RB30 you planning on building?
Just the typical rb30 route, forged rods and pistons, maybe cams, nothing spectacular.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
