nismoR34 - i think rob was just giving you shit for fun, not saying your wrong in pointing it out.. but on the other note - you'd have to be stupid to read "dail up 8000rpm" and then go and actually do it.... however, i guess some people take everything they read here for gospel ..
https://www.sau.com.au/forums/topic/28109-burnouts-d/page/2/#findComment-587058
Ok, I do apologise for posting saying 8000rpm was a good place to drop the clutch.
In a standard R33 GTS-T, I would still recommend around the 5000-6000rpm mark as this will ensure that the tyres break traction and can spin up quickly and efficiently.
A burnout will take of the same amount of tread as travelling the same distance while rolling. The fact that you aren't moving anywhere doesn't make a difference.
Just a quick note to draggers who wanna warm tyres before running. Everyday street tyres are designed to operate most effectivly at a specific temperature. If the tyre heats to a point past this temperature, you will actually lose traction as the tyres have been slicked up.
I found that on street tyres, a burnout really isn't necessary as these tyres are designed to work better at a colder temperature rather than hotter. If you really wanna do one, simply a quick burnout without the brake would be sufficient.
That is all...
https://www.sau.com.au/forums/topic/28109-burnouts-d/page/2/#findComment-587148
well stated!
I agree that street tyres are generally a waste of time for burnouts [tyre warming] - now tell all the officials at the various drag strips because they expect you to do one, though I suspect they just want to please the crowd or something...
I do need new tyres though - and a clutch!
https://www.sau.com.au/forums/topic/28109-burnouts-d/page/2/#findComment-587188
Handbrake will simply apply more braking to the rear wheels making your engine need to work harder to fight against it. THe brake pedal has more bias toward the front brakes, hence better for rear end to spin. Try getting a line locker to prevent rear brakes from working at all. It makes burnouts a breeze. Then again, they already are, and also, tyres are expensive.
https://www.sau.com.au/forums/topic/28109-burnouts-d/page/2/#findComment-588351
  • 4 weeks later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
