Dear Skyline Owners,
Skyline's monthly cruise is on again. We are meeting at City West Car park on Tuesday 4th of August at 7.30pm and 8pm depart. For those who don't know City West is located on the corner of Railway St and Sutherland St, West Perth.
As you know these cruises are restricted to Nissan Skyline vehicles ONLY!
We place a strong emphasis on safe driving at all our Club Cruises, so if you intend to come along please obey the road rules. Inappropriate driving will not be tolerated. If we see you driving stupid expect that as your warning and you wont receive a map at the next cruise.
So come down for a bit of weekly/monthly fun :rofl:
If you want to write a monthly cruise map please PM myself and or Sami_
https://www.sau.com.au/forums/topic/281273-skylines-monthly-cruise-002/
  • Replies 65
I will be there. Wana take the car for another cruise before i go down to bunno for the members cruise. Got a miss im still trying to solve with the car.
Should be good as before.
is this a SAUWA members only cruise or anyone who has a skyline can come
Anyone with a Liner man.
Usually the SAUWA cruises are in the members thread and aren't accessible to non-members.
I'll be coming, will take Passive's car :)
PLEASE behave to people that come! I know 90% of ppl did last time but yeah, hopefully we don't have that 10% again heh...
Will see you all there!
Same question as dave_rb20
with this be a northish cruise again? or are we heading south??? cruise direction dictates how long i am out :)
i'll prob ride shot gun with neuro like i said, im always pathetically tired :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
