Just to add a bit of fuel to the fire! I had a bit of time up my sleave and was bored so I made up this graph. Now it's not perfect, there are different dynos, different boost levels, different correction methods etc etc but it gives a decent indication of levels of response and overall power on stock stroke rb26's.
Green Line - 2.6L Garrett T04Z 0.84 (24psi) on modded china manifold, HKS 272 10.25 cams and decent head porting
Yellow Line - 2.6L Garrett T04Z 0.84 Split (24psi) on 6-boost split manifold, JUN 272 10.5 cams and no head work
Black Line - 2.6L Garrett 3582R 0.8x T4 rear (28psi) on china manifold, TOMEI 270 10.8mm cams and no head work
Blue Line - 2.6L (the motor from the yellow line) but with Garrett 2860-5’s (24psi) on 6-boost low mount manifolds
Pink Line - 2.6L with HKS GT-SS (18psi) on Tomei manifolds with Tomei 260 9.15 cams with head porting
Anyways a picture tells a 1000 words (sorry about my shocking excel skills)
Edited by Cerbera
https://www.sau.com.au/forums/topic/281368-rb26-dyno-comparisons/
I'm not trying to discredit what your trying to do - but different dynos, different days, different strapping methods, different setup methods, possibly different rolling diameters, different drive ratios, different tunes, different cam timing, different ramp rates, different tyre temps - the list is endless!!!
I can tell you from expereince that on a Dyno dynamics dyno that even getting consistant runs from day to day with no modifications performed is a task in it self. I usually get within +/-2.5% of the previous runs with the methods we employ with no changes. You need to get all these cars on the same dyno within 2hours of each other for real comparison. I would get the tacho numbers precisely calibrated so you can compare in rpm not vehicle speed.
Dude, everyone knows that (it was only a matter of time before someone jumped on it), it is just a rough comparison for people to see, we are on a forum not in a laboratory.
Keep the comparisons going, can you put "twoogle" on there, I am sure Paul won't mind.
Mike
Mike
I just dont see the point in comparing when for example there could be the difference between the 35R run on a happy dyno when compared to a TO4Z strapped tightly on a low dyno and they both read the same power now is that to say that the 35R is the same size as the TO4Z???
Thats why I hate these threads becasue the results are arbitary!!!
i said pretty much exactly the same thing in the original post... i have accounted for a few things you have listed though
tacho numbers are directly proportional to rpm... this graph actually translates 2 graphs from rpm to road speed, i can repost it in rpm if you like!!!
Edited by Cerbera
Mike
i cant find a twoogle graph in rpm and the ones based on road speed seem to be in 3rd gear (he has a os mission so i dont know the road speed/rpm relationship)
Yes but different cars may have different diff gears and tyre rolling diameter so while 4th gear is usually 1:1 the rpm/rev ratio may be different car to car.
What is the purpose of this thread??? Are you comparing turbos or engine setups or what?
all 3 cars done by road speed were r32 gtr's with 1:1 4th gear ratios, 4.11 diff gears and very similar rolling diameters (2 exactly the same) the other 2 cars were on rpm... i know the rpm relationship between speed and rpm in the r32 gtr's so i can translate from there...
turbos comparison mainly, most the motors have very similar specs
Edited by Cerbera
the red line i added is a rb27 with t04z on 22psi and pump fuel and only revved out to 6800rpm roughly on that run (misfiring above that so we called it quits), usual redline is 9000-9500rpm. This dyno reads very low too compared to some of those numbers on there :angry:
Edited by unique1
looking at the graph however inaccurate it may be the yellow line twin scroll t04z setup looks the bees knees compared to the others. same response as the 2860's and loads more top end.
I still can't decide what turbo choice to go for with my new build. 26/30 twins or twin scroll is the question ;) response is the main goal but i wouldn't mind getting 350kw+ i was origionally thinking of slapping some ss's on there. be nice to have the cash and your own dyno to change them all over and pick :happy:
Edited by GT-RZ
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
