  • Replies 40
nothin to do with handbrake.
if engine is turning/running... once nav is on, the magic button refuses to turn it back off....
magic button only works when engine is off, or when I turn off the engine and restart it again (in magic button off position)
and don't touch it...
ok thats weird. I took that car down eastlink with it on and off and it behaved. pop past on sat and we'll go fro a drive. actaully I'll all you in the morn.
it works on and off while driving with the other trip computer screen/ original jap nav...
but not on the tv tuner... once it's on, it refuses to switch back to the tuner. the only way to get the tv tuner back is to turn off / on engine to reset it.
wish u could tell me 'cut the yellow wire' thing that'll save me a trip down... LOL
sat might be difficult, i need to look after the kid while wife's away.
the V35's ciggy lighter might be too deep for it, or it just need to turn sideways at an awkward angle...
upon further search I found even more weird stuffs.. some looks like one of those StarTrek USS entrprise space ship...
I can't help but laughing at the shape of this. must be a star trek fan who design it.
an example of Chris' work on my car...
this is not a setup for the faint hearted IMHO...
trying to make the Nav to work on top of JDM trip computer, TV tuner, and the reverse camera!
had a few hair pulling moments to get it right but Chris finally cracked it!
good job Chris...
http://www.youtube.com/watch?v=pGyiOfF2z8s
thank you!!!!!!
the issue you had I had a GOOD think about. turns out that we were latching that relay on . when I pulled it the latch broke. hence my fix.
the video is now going to be used on my site as a demo for these cars. (I'm taking a copy as well in case you remove it.)
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
