ok i need to get rid of these asap. all left over from an unfinished project. all new and unused. all were for RB20DET.
Garrett GT3071R, T3 flange, 56 a/r, .64 rear housing.
Xtreme clutch and flywheel, single plate, good for 300kw.
Nismo 600cc injectors, purple, also good for some RB26.
HKS 256* exhaust cam and camgears, gears for any RB engine.
$3000 the lot as prefer to sell as a whole but just need it all gone. pics on request but im sure you know what they look like.
that is all....
https://www.sau.com.au/forums/topic/281797-need-to-get-rid-of-some-parts/
yes you will need a computer. i was going to use a haltech that ed from autotech was going to get for me. fuel pump if you dont already have one. boost controller. the turbo is fitted with a 14psi actuator. turbo will need a spacer plate to keep the comp cover away from the ex manifold.
but thatd be it you reckon???
unfortunately im not in need of a clutch...willing to seperate???
yeah im pretty sure. i took all the parts in to ed to look at and he told me all that needed to be done.
you might need it one day lol.
How much for the exhaust cam. and also whats the part number?
seeing how i go selling the lot first or if there is enough interest in each part then yeah. i think i got sent the intake cam papers. the only thing i can see on it without taking it out of its bag are '2', '708', 'N174' and 'HKS'. but the part number is 2202-RN175.
umm, R32 R33 R34 GTR and R34 GTT use pull type. R32 & R33 GTs-T and the N/A skyline use the push type. CMIIW.
i guess RB20 and RB25 have different diameter size.
mannn, if u can do layby for the turbo, i'll prolly take it. since we're in the same town. lol.
  • 4 weeks later...
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
