Hello all,
Skylines Australia ACT have been extended a personal invitation from Ultimate Tunes to attend a new event that will be taking place in Phillip on the 5th of September 2009...
This looks like it could be a great event for local Jap car enthusiasts and will surely grow in popularity in the coming years... So lets show our support! :)
I have been told that there are limited spaces for the show and shine (60 in total) and there has been quite a bit of interest from other local car clubs already.
So put your hand up (or name down) if you are keen on attending the FREE Show 'n' Shine and / or DYNO Challenge so that we can get some idea of numbers.
Also - there will be prizes and giveaways on the day for entrants to the Show 'n' Shine and the DYNO comp, so as the ad says - start polishing your ride!
I'll start us off...
1. Bullet32 - Show 'n' Shine
https://www.sau.com.au/forums/topic/281878-jdmfest-2009/
  • Replies 104
Posted Images
I'll have a bash at the awd category but I aint got nothing at the rears compared to what some of those Supras are putting out there.
I might come down for a look but there's no way in the world I will ever put my car on this dyno ever again. I had a bad experience there the one and only time I was there and that's enough for me. I've forked out too much cash on my car to have it harmed on a dyno.
I'm not sure if there are any other Supra's attending though, I'm just down the road so I'll pop down to check out all the cars.
Cheers
Ross
https://www.sau.com.au/forums/topic/281878-jdmfest-2009/#findComment-4752890
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
