im selling my rb25det motor comes with everything except for
turbo
ecu
starter motor
as these was taken from this motor and put on another rb25
motor has 80,000k from a rear ended write off engine ran perfect without any smoke or noises
was gonna convert my 180 but some forum member ripped me off for 2g's so now i cant finish off the project.
engine is in canberra
you'll have to call me for an inspection as im in melbourne.
$1500 ono i just want it gone
0433443055
https://www.sau.com.au/forums/topic/281906-rb25det-motor-loom/
sorry cant do compression test now as everything is out.
from memory i can get it delivered to melbourne for around $250 - 300 but i can double check for those interested
engine came from a 97-98 i believe. and it does come with engine mount brackets but the mounts i would say are better of getting replaced as i threw one out since i was going to used custom ones from USA for my conversion
engine does come with all wiring loom but no ecu
Edited by DUU MA
$500 + delivery to Darwin??
lol... Details of rb20 and clutch? Details on the wreck the rb25 was taken from? Modified heavily/lightly? Any idea of the legitimacy of the kilometers?
RB20 was in good working order and is a standard clutch. looks in excellent condish but have not tested as it never was installed on my car.
engine was a pretty much a stocka from a 33 with kit and exhaust and rims which got rear ended and KMs are as legitimate as the tacho says.
was run on 12psi boost
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
