That's exactly what I had but without the heavy steering. :) Definite crab walk. Happens at higher speeds like 80km/h and you need to steer into it and if slow down quick a flick out of it. I recently had work done on the suspension but the steering wheel is not that straight after the alignment and wondered if that had anything to do with it...? Speedo cable is all good.
well if the steering wheel isn't straight that'll be your problem. there are two sensors up in on the steering column that tell the HICAS ecu that you are turning the steering wheel and which way. if your traveling along at at higher speeds, when HICAS becomes active, and because your steering wheel isn't straight the steering sensor is registering that you are turning the steering wheel, even though you really aren't, it will make the HICAS start steering. if your ok to do it yourself just pop the steering wheel off and line it up straight, or just take it back to the place that did the alignment and tell them to sort it out.
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4755500
Having a think the sensors aren't in the wheel itself, so the wheel could be on upside down and it wouldn't effect anything. Looks like I'll have to lock up the HICAS.
correct the sensors are mounted to the steering column and the steering wheel boss activates the sensors when you turn the wheel. you should be able to slide the whole steering wheel boss off and jump it over a spline. it will require a fair bit of persuasion to get it off though.
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4759332
Okay, sweet. Thanks again Josh.
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4759336
if you havent removed a steering wheel before, be VERY careful and dont remove the nut completely before you attempt to remove the wheel. leave it on a few turns so it doesnt smack you in the face when youre wiggling it off!
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4759350
Thing is, if the steering wheel wasn't removed immediately prior to this issue, it can't have moved on the spline.
Removing the wheel and re-orienting it will not correct the original source of the problem.
The rack centre position could be offset to one side, causing your problem.
You should turn the wheel from centre to lock in each direction counting the number of turns, if it is unequal in either direction, any adjustment should be made at the rack ends with the rack centred.
Then you can be sure that your rack (and therefore) steering column and wheel are centred correctly.
Good luck.
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4759796
what work did you have done to the suspension? height adjustment by any chance?
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4759895
Hahaha I've done it a couple of times so won't have that problem!
Good luck.
Great post, thanks for that.
might also been the rack bushes too! if they are stuffed, it will cause the rack to move also. its possible its just jammed in the wrong position.
I only just had them done. If some things weren't done correctly can that lead to these issues?
Bilstien coilovers, cambers kits and traction rods and all sorts of random shit. I really don't know a whole lot about suspension sorry. :( But definitely height has changed, it's certainly lower.
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-4760905
  • 1 year later...
open your eyes before your mouth please
pull ur head in smartass, i was making a valid point about a possible scenario. which has nobody has proven otherwise or posted anything to the contrary. its entirely possible that if the front washed out on turn in, that the rear turning away from the corner could turn you off the road/track. maybe not a common situation but possible none the less.
https://www.sau.com.au/forums/topic/282242-hicas/page/2/#findComment-5918242
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
