Hi Peeps - I need to vent - apologies in advance.
I'm a bit pissed:
* The Gloria took heaps longer than expected to arrive (no-ones fault, it just did)
* Spent ALL last weekend doing it up for blue slip (when I say all weekend - I mean 7:30am till 9:00pm Sat & Sun)
* Didn't risk the snow tyres so spent $750 on 4 new tyres
* Took the wheels off the car , put them in the boot of my old mans car , took them up to Bridgestone for the new Yokos.
* Custom made tinted acrylic covers for fog lights as the glass was busted on them when it arrived
* Re-Sprayed front bar where there were a few scratches
* Fitted Child restraints as I thought they would ping me for not having these (anchors were there but not the hooks)
* Cleaned and polished the shit out of it (came up nice BTW)
* Installed and wired new horn as none came with it.
* Fixed all the lights and bulbs etc
* Fixed the speakers and stereo
* Removed remote starter
* Removed all the rice that the Japanese owner had in it (weird stuff like mobile phone holders and this shit that was double sided sticked all over the inside)
* Checked and cleaned all brakes (pads and disks, front & rear)
* Oil Change
* Oil Filter Change
* Air filter change
* Fuel filter change
* Cleaned and de-geased engine bay
* Cleaned and de-greased wheels
AND GUESS WHAT - THEY FAILED ME (Blue Slip) FOR BAD FRONT UPPER SUSPENSION RUBBER (the bit between the strut and the chassis)
FARK, FARK, FARK.
I was hoping to have it registered tomorrow so I could go driving on the weekend -
I haven't driven a car properly for like 5 months - Ahhhhhh
I'm a bit dis-appointed - but I vow to move on and fix it all !
And the Gloria will be registered - First Y31 in Oz !
Frigging Blue slip inspection stations........
Actually to be honest they were pretty good about it - instead of failing me , they said ' go and fix it, bring it back , then pay us and we will stamp the blue slip'
So It could have been worse - but I am still pissed !
SO - If anyone know where I can get a genuine OR replacement OR similar for other model : Front Strut upper suspension bush/rubber for a Y31 Goria - then please let me know ASAP
/ end rant
https://www.sau.com.au/forums/topic/28245-b-mans-vent-of-the-week/
Yes Phil - that's what I have to do.
I'm going to ring Hornsby Nissan today to see if they can match the part via part number to another model - hopefully it is the same as another Nissan !
Ahhh !
Ahhh !
It just so happens that the new guy sitting next to me at work was a mechanic at Hornsby Nissan until he got this job. Maybe he can help in your search
I don't think compliance makes your car roadworthy - that I think is seperate.
The compliance people ensure that it complies to Aust. Design Rules. Eg: Seat Belts, Childs Restraint anchors, Side Intrustion Bars and Engineers Certificate.
All of this was done (yes it took a bit longer than expected)
The Blue Slip is the same as a pink slip but with a Vehicle Identity check (checks for re-birthing) -
So - the bits I need (The upper strut rubber bush thingies) were the only thing that they found wrong with is - and really should be changed.
If the car was a Falcondore, they prolly would have been able fix it straight away but alas - I chose a unique Nissan.
Anyway - I rang Hornsby Nissan and they can get the parts - $60 each Ex. Japan - 2 weeks wait !
AHHHH - Still no car for another 2 weeks !!!!!!!!
Furken Furken
At the rate this is going, my R33 will be back on the road before the damn Gloria !!
Even worse than warm beer is NO BEER.
Got home after 2 weeks in the desert and there's no beer in the fridge. :(
B-man, Y, oh Y31?
I take it nothing local matched it. We should take our hats off to Hornsby Nissan, they've been doing a good job supporting these imports.
Yeah - Hornsby Nissan ROCKs.
They were really really helpfull. Even faxed me a copy of the exploded diagram so we could be sure that we are talking about the right part.
They have the entire Nissan Parts catalog on CDROM. Even imports like the Gloria - of which the guys at Nissan are going like WTF is a Gloria -
All they needed was the chassis number - and bob's my Auntie.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
