R33 gtr V-spec Turbos, only 40,000klm Old. - 500
R33 gtr V-spec exhaust manifolds, - 250
R33 gtr V-spec dumps and y-piece - 300
R33 gtr V-spec cat - 250
R33 gtr V-spec injectors - 300
R33 gtr V-spec fuel rail - 100
R33 gtr V-spec fuel pressure reg - 50
R33 gtr V-spec cams - 250
R33 gtr V-spec cam gears - 50
Mines R33 gtr V-spec tuned computer - 500
R33 gtr V-spec pistons - 250
R33 gtr V-spec rods - 250
R33 gtr V-spec fuel pump - 150
Nismo N1 Oil Pump Used But only 5000 klm old - 350
More to come
No pics yet, they will be up next week.
can do deals for more than one item.
Pm me
https://www.sau.com.au/forums/topic/282580-r33-gtr-v-spec-parts/
  • 4 weeks later...
no heater hoses sorry.
and no shaft play on turbos, they are like brand new.
not sure bout postage would perfer to sell turbos with whole set up
  • 1 month later...
  • 5 months later...
