Put my sky here ;) Location : Perth , WA
Car Details
1998 Nissan Skyline R34 GTT
Black
Engine Modifications
Apexi Pod filter
HKS SSQV Blow Off Valve
Custom 3? Dump Pipe
Custom 3? Front Pipe
High Flow Cat (3?)
Xforce 4.5" Stainless Steel Muffler
Suspension and Wheels
Lowered springs
Rays Wheels : Nismo LM-GT2
Tyres Toyo : Transas Cruz 17x8 , 225/45/17 Front; 17x9, 255/40/17 Back
blank_separator.gifInterior:
Momo Gear Knob
Blitz FATT Turbo Timer
Stereo:
Sony Xplod Head Unit
Sony Xplod 6 Disc Changer CDXT69X
Exterior:
C-West Front Bar
C-West Side Skirts
C-West Rear Pods
C-West Rear Bar
R34 GTR Rear Wing
Autowatch Blue Series Alarm
Only 36.000 km on clock
Picture can be seen here -> http://www.cardomain.com/memberpage/423101
Thank You
[email protected] for enquiries or 0412696558
Price : $35.000 FIRM
https://www.sau.com.au/forums/topic/28264-r34-gtt-black/
  • 4 weeks later...
  • 1 month later...
This is a nice GTT....think about it Erik...I'll give you what you want for your car no questions and you can trade up to my car. You know what I want for it so it's just a matter of coming up with the difference.
PM Me if you come to a decision. Just imagine crusing the west coast in a GTR??? and being only 21, you'll have women all over you. hehe
https://www.sau.com.au/forums/topic/28264-r34-gtt-black/#findComment-667706
iv'e got a model car :D will that do? btw swoop your car owns
https://www.sau.com.au/forums/topic/28264-r34-gtt-black/#findComment-667909
