yes the rb26dett does fit into normal gts-t's (well i have seen and heard about plenty of conversions etc from the standard RB25DET to the RB26DETT)
The engine itself is alot more powerful i believe and theres also a few extras that come with the car ... i think.
its just like pathetic holdens etc,
They have SS models, HSV etc etc the GTR is just the more advanced, more powerful model of the GTS-T
Mostly those two things, but a few other subtle differences -
Added gauges to GTR
Different bodykit/wing/front bar/badging
Bigger fuel pump on GTR (bigger injectors etc taken as given on the different engine)
Different gearbox (different ratios)
Bigger brakes on GTR
Different wheels (forged alloy on GTR I think as opposed to cast on GTS-t)
Flared guards on GTR
That's about all I can think of right now, I'm sure there's more but that's probably most of it.
You can put an RB26DETT into a GTS-t without too many hassles. If you want the 4WD though, a better conversion is to drop one in to a GTS4, which has the same gearbox and 4WD system as a GTR.
Either way you are probably looking at around $10k for the conversion including parts and labour, plus a lot of time off the road. It can be viable if you buy the original car cheaply enough at the time.
Not to mention suspension, drivetrain, 4wd system, computer system, internal gauges and dials..
no comparison really :)
Kind of like the difference between a BMW 318i and a BMW M3.. the only similarity might be the BMW badge. Maybe instead of listing the difference we should list the similarities.. we'd be here for less time as the list of things they share is quite short :)
  • 4 weeks later...
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
