  • Replies 68
What specks did Kip build it to?
I asked for the biggest wheels that would sensibly fit, on a bush core. Very similar to the skyline rebuilds he does. It could be good for 250? Im not sure the box would take it though.
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762187
the box should be fine
,mine is all a-ok with 240rwkw
and I expect the auto to be as fine with another 25rwkw thrown on top
over time it may get a little loose, but nothing like changing a clutch every few yrs
perhaps in a decades time she may need a rebuild or strengthen up but that'd be about it.
service it regularly with good fluids along with shift kit and you'll be alright
nice turbo. bush bearing tho? went from bush highflow "2530-size" to ball bearing highflow "2835-size", massive difference in power delivery
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762199
Im not sure which box is in the 34's, are they the same as M35? Mine was slipping badly when I took it in, needed a full rebuild with extra clutches fitted and valve body. Kewish are not sure it can take that much at the wheels.
Main problem with the ball bearing cores seems to be the excess heat in such a confined spot under the engine. I am hoping to get good life out of this one.
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762436
scotty,
That looks great.
Do you know how big it is built, ie. Gt30 or Gt25. It looks a bit smaller than Danny's.
Can you say what the cost was?
Cheers
Andy
Its about gt30 size, not that ive seen one close up. It would be about 2 inch inlet I guess.
All we can go by is what those same wheels punch out on an rb, around 250awkw. Im sure with the weird standard exhaust manifold, there will be more restriction.
I guess we will see the outcome soon, I will have to get it back on the dyno straight away.
Edited by scotty nm35
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762548
well, one is a 4 speed, the other is a 5 speed to begin with. i dont think jatco made the C34 box either, whereas they manufactured ours.
Pretty sure Nisaan have been using Jatco boxes in Skylines/Stageas since S3 R31's
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4763723
whats similar is that they are auto stags with highflows....... its all the same basic principles / theories.
S1, S2, M35, all stags with the varied stagea features, auto boxes are auto boxes, and high flows are highflows. again a variety in types..... :)
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4764035
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
