Hi!
I´ve got some synchro scrape/noise when switching to fourth and fifth gear.
I´ve been told that this is a common problem with the R33 manual gearbox.
Who in Perth could rebuild an R33 gearbox and has someone got an idea what it would cost?
https://www.sau.com.au/forums/topic/283155-r33-gearbox-rebuild/
yeah but when your synchros are gone its a pain in the ass. cant shift into certain gears at higher rpm's. I mean its still very driveable but as they said you can replace the g/box with one from a wreckers but who knows if that doesn't have the same problems. Replacing synchro's will set you back about $1000 + labour.
Hi!
Try some Redline oil first
I have the same problem, crunches at high RPM going to 4th. might try some Redline oil first, but am considering rebuilding the box if or when it fails.
If i was to get a box from the wreckers is there a fair chance it could be also hammered n soon will scrap?
If i was to rebuild is there any way to make the syncro's and gears stronger with aftermarket parts? or a is there other boxes you can put in that are better / stronger?
well if you want your gearbox syncros replaced i had a few replaced and my gearbox fixed up (bearing was fked inside it) at perfect transmissions in bibra lake, awesome guy knows his transmissions! him and a friend were the only ones to actually guess RIGHT what was wrong with my car..all other mechanics wouldve cost me 2k+ (due to them going to replace the clutch first...) only cost me 1k total for new syncros and some bearings fixed oh and new thrust bearing just for the sake of it (even though i had a new clutch in anyway) :P
basically took the car to the shop to get a crunching fixed (was the bearing) and he fixed it (he does cash jobs to)
uhm wasn't a recon but he atleast told me the condition of the gearbox which is it's still good (strong gearboxes :()
but yeah...1k cash for labour + syncros (2nd and 3rd i had replaced i think it was...) + bearing + thrust bearing
my advice is though if you DO see him... ask when he actually NEEDS the car.. cause he had mine for a couple of weeks lol before he got to work on it (he can be very busy) like 10 cars somehow fit into his shop... i dunno how haha
good place though ;) great guy
uhm wasn't a recon but he atleast told me the condition of the gearbox which is it's still good (strong gearboxes :( )
Sounds like it´s worth to pay them a visit. Should be alot cheaper if I just get the gearbox of and hand that one in... should save some money on labour...
Also what I was thinking.
Anyone know if it's true that 34gtt boxes have dual synchros?
i've heard of that before... i can possibly call up the dude who took apart my gearbox lol but yeh... i mean i had the option as well as goin well do i fix my gearbox.. or replace it... it came to the 'if i replace it...it could be as rooted as my current one :S'
so i fixed it :(
so i fixed it :down:
I´ve come to the same conclusion... What if.... That´ll suck!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
