Yo VIC people, project FATLINE has started
  • Replies 104
Rob: thanks mate, yeah, i tried uploading today and it worked :P
Sentric Dancer: stock Mspec body for now, apart from low drift wing (see pic earlier). The only front bar i really like is the Trust GTR bar - same as Merli's. I think it will be hard to source, so maybe in time i will think about it.
Hey there Marcus...
You wouldn't have previously owned an E30 Beemer by the way??? I'm friends with Rohan L, and he was apparently negotiating to buy some wheels off you at one stage....We met b 4 you got the 'line (or am I going off on some idle tangent)
Paul
The covers were acid dipped then painted with oil/fuel resistant high temp paint.
The car's stock apart from the plenum, fmic, exhaust and boost...
155 is pretty much spot on for those mods excluding the plenum.
The plenum has much lower velocity than the standard plenum at lower volumes, and theoritcally should loose power over a standard manifold at low power.... it's when the new turbo goes on and it gets wound up we'll see some results!!!!!
Doc.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
