The wheels and wheel nuts were taken from Sunnybank Hills on friday/saturday . its a dead end street, so almost has to be a local or a friend of one.
Anyone with any info will be completely confidential.
call or sms me on 0400 039 899 or pm me.
i cant figure out the new NS.com so if someone wants to post on there for me, feel free
cheers
Jason
https://www.sau.com.au/forums/topic/283746-stolen-fron-sunnybank-hills/
cheers
Jason
Seriously what a low act!! The person who stole them deserves to be shot. good luck getting the wheels back
yeah, the car was parked directly across the street from the house. and noone heard a thing.
no locknuts. stupid i know, but i've learnt my lesson now, i can assure you.
cheers
Jason
Lock nuts? I'll keep a lookout for ya. Those rims arent really common.
Lock nuts help but won't stop a determined thief really. That sucks though. Such a dog act. Insurance?
cheers
Jason
Hi Jason
Did the police come out and dust for finger prints as I dare say it would take a couple of guys with gloves. It may be worth doing a report with as much details on the wheels as possible. A good mate had his car stolen & paid out by insurance but it didnt cover all the extra's, 3 years later the guy got caught and got a pay out.
Good luck at least they didnt take the whole lot; it had prompted me to buy lock nuts
Yeah, the police have been out and dusted etc, but the car wasnt insured as its not long been registered, and has done almost no kays since rego, insured now though. didnt tell them it currently has no wheels, lol
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
