got a Ruzic TSC , doesn't have much in the way of installation instructions.. I have done some work on my car Before eg, clutch, gearbox etc but nothing on the electronics side so could use some help with this one.....
most of the wiring looks to be straight forward, just match up the colours of the wires.. BUT I've pulled the dash, centre console and centre gauges, stereo etc to pieces, to connect wire to back of the front torque gauge to the + screw as described ( trying to follow instructions I found on here ) there is 4 screws with 3 of them marked os its not obvious which is the + one... is it the top right as I suspect.. ( when looking at the back of the gauge )..also is it ok to just tap into the stereo power + & - ,, as for the toggle switch can I use the aerial switch on the dash it only has two wires going to the back of it and the toggle switch only has two also, will that be ok ( the aerial has never worked but reception is fine )
If there is anyone in perth who has done this before and would be kind enough to come round and help or if anyone can just answer the questions above that would be awesome..........
Try checking out this post for some tips if your still keen to try it yourself
http://www.skylinesaustralia.com/forums/As...ue-t266312.html
yeah thats the one I'm trying follow, lot easier when you have someone who's done it before with you......
I see he used the stereo power, I was just hoping there was somewhere more accessable...
cheers
The stereo power is right below the gauges (front torque split gauge) which I had to connect to, so I thought that was a logical place to get power from.
Good luck
paul (mountainrunner) is on these forums if you are stuck.
good buy :D
yeah he's just messaged me and said the best place to get the power is from the same place as ECU & also I think he said the wire to back of gauge is only needed for when you use external data logging !! just waiting for confirmation of that...will post up what I find out for others....
ok job done ...not exactly straight forward with those instructions and wiring diagram..firstly on all the paper work including the wiring diagram they refer to the G-sensor and then on the wiring table it starts talking about an Accelerometer ???? I asume that is is G-sensor ( if I'm wrong I've fkd it ) and also if you tap into the drivers side of the g-sensor plug (as these are wires the wiring diagram describes) then the Lateral G signal from G-sensor & lateral G signal out to computer-- are the wrong way round !!!!
anyway that was my experience ...... good luck to anyone having a go....icon9.gif
still haven't had a reply from mountainrunner, so I just took a punt and did it the way I thought made sense..
If you know how to improve the instructions I wrote please feel free to contribute, it wasn't a very difficult install but it could have been if I didn't get guidance from someone :down:
Yes, pretty sure accelerometer is the G-sensor located under the centre console in the R33/R32.
If you know how to improve the instructions I wrote please feel free to contribute, it wasn't a very difficult install but it could have been if I didn't get guidance from someone :(
Certainly not criticizing your instructions, couldn't have done the job without them :blush:
as the unit doesn't come with any how to....
If I get time I might add some to your instruction tread..
cheers
The product is obsolete or almost obsolete.
It's Paul's hobby and not really a mainstream business.
He only made a couple for enthusiasts so there was not enough profit to put a lot of R&D in the instruction.
I think he has been making a few more as requested but he is busy with other projects now.
I intalled mine and thought the instruction was fairly straight forward.
You should get a power source that is on when the key is ON and remains on during Start.
I wired up a relay switch from the ECU.
Edited by 9krpm
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
