looking for good quality low profile floor jack and jack stands. already have sourced Jack pads specific for the car.
Anyone have a supplier for these. after some advice re best fit for my car so would prefer to talk with a 'local guy' not buy over the net.
Cheers
Wow snap on tools are usually pretty expensive no? but uh autobarn and repco usually have regular sales on that sort of thing might want to check that out
EDIT: :down: I just noticed what car you have........Drools
i got one from DIYtools.com.au, $300 and came day after payment.. its an alloy, low profile jobby that moves around very easy..
check out waranaimports.com or .com.au for alloy jack stands, $99 for 2.
I got one of these puppies from Bursons for $380ish trade price.
not ultra low, but does the job, and its a LOT more rugged than my old aluminium jack which shat itself after some heavy use.
i have a snap on one its freaking awesome....
Hows the second mortgage treating you? haha.
I bouight a cheapie one from trade tools, nicely low up front, but at the back, it get's high. It's an Omega, i think up front it's 63mm. Freaken heavy at around 40kgs tho, but pretty sturdy.
not being ... how do i put it... errr.... one sided or sounding like a total wanker, but my jack is alot better designed than any of the ones above (seriously no offence intended)
i have a hsv gts that was 80mm high at the skirts and i could jack that up easy as pie... i work on alot of drift cars and the like so it was worth me spending the money
yes they may have an approach measuremt around 70mm but only at the absolute tip of the jack.... which in most cases renders the jack pointless if you have a very low car as most jacking points and inbound toward the centre of the car 100-200mm even more at crossmember or diff.....
the version i have was the most expensive but was the only one i saw any point in .... it has a 60ish?? mm aproach height and maintains that height for about 400mm and has a very very light lift height and rate (6 pumps to full height) because of this length
yes i am very biased... but for a very good reason
Edited by WHITE R32
wow, you really are an insensitive, single sided wanker, you really hurt me there. haha. Your jack sounds awesome, could never be able to justify getting one though. What you said is exactly the problem with mine, low at the jacking bit but going towards the pump bit it usually catches skirts/bars, sucks for cars with jacking points on subframes, etc.
haha nice, expensive stuff but it's worth it, from what my dad tells me LOL
All the 'low profile' ones i've ever seen are low at the front but get just as high as others towards the back, so they really aren't that much better anyway. I'm still content with driving the car up on my chunks of wood and going from there. Until I have a spare $800 that is ;-)
  • 5 months later...
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
