where is the cheapest place in aust to get an ATI? I have family in the US might be able to send a few over if its worth it
I think we were quoted $930ish from hioctane or someone like that. Shipping from the states and the average dollar then import duties/GST.. almost worked out the same :down:
And yeah, was going to suggest Ross.. AFAIK, ATI only do 26 balancers.
yeah but if you only got 3 per time sent from a residential address in USA to a residential address here i dont reckon they could sting you the 27% tax or what ever it is
performance wholesale last time i rang was $714
While we are totaly off topic, anyone know of a good ballancer for an RB25 specific belt setup,
give Ross a call as they can make a custom balancer to suit ur application
I won't use an N1 pump again, I just had one fail and it's ugly. Just lots of little bits of smashed gear and the consequential damage no oil pressure causes. The extra dollars for a Nitto pump are well and truly justified compared to the time & cost of fixing the damage a broken pump caused. I've used 50 or 60 in the past without a problem but am now really paranoid about using one again.
We've got a heap of billet oil pump gear blanks machined up ready to cut the gear teeth on, anyone interested in a billet chrome moly set of gears that will fit into a factory pump housing? I'm just weighing up the cost of finishing them off, from memory we have about 50 sets semi machined. Also considering making then spline drive like a Toyota rather than the 2 flats.
what sort of $$$ are they going to be?
as previously discussed greg - i think your above idea & in particular the spline drive is right on the money!!!
hypothetically speaking, it is much better having the stress over say 12 edges rather than 2 edges, but then i also wonder why hasn't anyone done this in the past?
The problem is, you haven't paid GST on them. The import duties only came to about $60, it was the $300+ in GST that really pissed me off. Residential to residential you might get through. Like I said, I've run the gauntlet before so I guess I should be happy this was the first time to get stung.
I just recently got a collar fitted on my crank and because I'm anal about all things in my motor, I pulled the backplate off the N1 pump and checked the gear clearance. It appears that the guy who did the collar for me machined the collar a fraction so it would fit easier. Now its seems a little looser fit on the gear. I'm not happy at all! Either way I'm getting it redone with a new collar and getting the reimax gears just for added security.
After what just happened to my crank, I wonder how many guys actually take the pump apart and check gear to collar clearances, as the company that did mine reckon they do it to all of their collars.
Definitely be interested aslong as the cost isn't exorbitant.
As for the splined idea, if you could supply a crank collar to suit then that could also be a goer.
And 20 cases is... 0.001%? :down:
Yes 20 random cases in 5 minutes of searching... and as somone mentioned, most people wont like to admit their motor had issues even if it was due to bad quality parts.
I suppose its my own fault, buy a cheapy N1 pump and hope it will last was a dumb idea on my behalf.
Marko, Toyota do it on most of their engines now, have done on their diesels for years. It's just that they are more labour intensive to make. It takes me 5 minutes to mill the flats on one of my collars, to mill 30 or so splines will take a lot longer.
It's a bit of a catch 22, to make a billet gear to suit the standard drive, the inner portion of the rotor needs to be wire cut as you can't mill that shape and I don't have a wire cutter and people that do charge a pretty good hourly rate for them and it's slow, from memory about 5mm/min, maybe newer machines are quicker. The rest of the gear is a mill-able profile and the internal splines can be broached which isn't a hassle to get done. I've got the rotor profile cadded up so that's not a problem. There's also isotropic finishing and heat treatment to do. I'll do some sums and see if they're still worth making.
How much are the gears you can currently buy? These wouldn't be cheap but they would be very good stuff.
Slow but damn accurate! We had the same issue when I looked at making replacement gears for one of our dry sump pumps that got damaged....however internal radiuses too tight for any cutter in the mill. Needed a wire cutter.
Curse the damn machines!
Kudos to you greg for having a go at sorting out this issue though. If successful will no doubt help alot of people out!
hey gary - you should go straight to the horses mouth & speak to jim from crd about the nitto pump...he has had over 20 years experience with the gtr & has been exposed to countless pumps (n1, tomei, jun, stock). he will give you the low down in about 5min :down:
Thanks Marko, i've bought the Nitto off Paul :/ And thanks for pulling out Rezlo, sounds like you got a good deal on an even better setup for your needs.
Gary
Even if you have a collar and with a spline that drives the oil pump gear you will still have the flats on the crank driving the collar correct? Seems like it is not solving the direct problem.
Double key would do a nice job too, splines are harder to get right. Easy to machine a keyway in the crank and a mating inner section of an oil pump gear. On an engine refresh just replace the keys. But it means crank out...
Mike
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
