The VCT on OEM engines is there to give you the best of both worlds.. top end and low end. It has its' benefits in performance applications but most people don't care.. they just give it more revs before they drop the clutch :D
You guys ever driven a car that had VCT and then got rid of it? SR's and RB's with VCT removed are shit down low. Hell, RB26's are shit down low. Not that many people care about such things on big power cars, but for a daily driver it does makes a difference.
Edited by PM-R33
Maybe your VCT wasn't working because there is a difference. Considering i can control my VCT with the microtech and turn it on or off, yep, there is a difference. Good mate of mine took the VCT off of his S15 because they tend to fail on the SR20 and he regrets it, very noticable power loss down low.
I'd be curious to see how a stock turbo RB26 would go with VCT on it considering i find them quite crap down low for what they are, however that's probably just lag from the twin setup (maybe this aint as bad on a R34, only been in R32 and R33 GTR's).
Edited by PM-R33
I'm in the states right now and a buddy of mine just bought a HKS V-Cam set up for his 33GTR. It has a fairly large single and pumps out 780 odd whp. He made alot more bottom end and especially midrange power with the V-Cam system set up correctly.
I would like simmilar results for my own 26, however I don't want to spend 5-7k on a brand name item.
I have an aftermarket ecu that I will be able to use to controll a pressure controll valve, I will have to get a cam custom cut, line up some oil pasages and use a 25 VCT gam gear? Then spend some (free) time in r and d...
I'm just trying to find out if anyone has had any results (good or bad) trying VCT on a 26 head.
Cheers
J
Baring in mind turning a VCT off is not the same as running a camshaft that is designed to run without any form of VCT.
I can see VCT having benefit on the road with stop start driving in traffic etc which is most likely the major benefit of having it.
IMO correct cam choice and adjustable cam gears is more than enough. In saying this i have never had a direct comparison.
Never saw anything too impressive in comparison with that HKS car either with the 26 VCT.
VCT is not all about low end power guys, its also about the efficiency of the engine, this is due to the overlap of the timing between the intake and exhaust camshafts (small duration favourable at low rpm and larger duration at high rpm, because of the time it takes the air to get into the combustion chamber) so essentially due to the increase in efficiency this also in turn leads to increase power and more importantly torque. personally I do not see to many issues involved with fitting the vct to a 26 head, just a little bit of machining required, but no reason why it would not be feasible, We would like to see this carried out, as it may well turn out to be a good option compared to the hks system and could be every bit as effective.
good luck with it mate, and if we find that anyone has done this will let you know.
you will probably find its cheaper to just use the neo head. why reinvent the wheel?
Exactly, MUCH cheaper infact, probably to the tune of 4k give/take.
For other than the sake of "saying" you have a RB26 head, i see little point in not using the RB26 head if you want the VCT and so on. the HKS V-CAM is too expensive for what it is when you can just put a NEO head on, and get an adapter for the RB26 intake side.
Who cares what head is on there? Does it do a better job, yes. So therefore you use it.
It is the same reason why some people (including me) dont want to use an RB30 block.
If you are sure it does a better job you must know more than most...? >_<
If you are sure it does a better job you must know more than most...? :D
I was comparing the 26 head to the 25 head.
VCT vs no VCT... pretty easy especially when the thread is about - VCT on heads
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
