Ive recently purchased a mechanical boost gauge for my r33 gtst and have wired it all up and pulled the vacuum hose through into the engine bay and after reading some previous posts (without pics) i am unsure of the best place to tap into the line for the y piece, should it be at the front of the manifold or at the rear? some people say one thing others say another could i get your professional thoughts as to where to tap the y into for the most accuracy.
https://www.sau.com.au/forums/topic/283875-greddy-mechanical-boost-gauge/
most people go spot 2, because it is closest to the firewall and a bit less obvious.
neither of these will give you the most accurate reading though. they will give you an accurate reading of how much boost the engine is getting, but not what the turbo is actually doing. to get an accurate reading of how much boost the turbo is producing you need it reading from before the intercooler, however this will not give you a vaccum reading like having it from the plenum will.
bump
I don't know why you need to bump it, you just got 2 answers and they're both the same.. it doesn't matter either 1 or 2 because with you both, you will read +ve and -ve pressure of the plenum. Just don't be a tool and mount it pre throttle body like some.
Well id hesitate to tap it off the FPR as mechanical gauges intrudce latency issues. Ideally it should have a short genuine line from the plenum keeping it responsive to intake variations. The best place to throw a mech gauge i believe is to a vac line that doesnt have critical components feeding from it.
I too have that exact gauge, have fed the vac line through but have been lazy in conecting it. So where have the others connected it to?
Funny you say that, the first night i plumbed it up i went for a few runs and i had the engine light come on. That was plumbed to the vac line from plenum to boost sensor?(R34) I have since pulled it out and no real issues since. Im assuming by taping that vac line it would be getting a lower reading than actual. Hence why id like to find out what others have done.
Someone a while ago said the FPR is not a good idea....
Cheers
Makes no difference, you won't even notice the difference!
if you don't believe me, connect to Boost Gauges and test it yourself :cool:
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
