i don't know if its been done before,but here goes i was looking through a brake disc book and found some merc ml55 345 discs/rotors i could alter to fit a skyline,all you have to do is take the centre bore out to 68mm from 67mm skimm 1mm of each side to take them from 32mm to 30mm and redrill the mounting holes to nissan pcd,then make brackets to space the calipers out,then grind some of the caliper away where the disc runs just enough to make the pads sit right and a space between the edge of the disc and the caliper for expansion,i bought the discs for £68 in the uk the cheapest 345mm discs for a skyline in the uk is £175,quite a saving if you no somebody with a lathe
https://www.sau.com.au/forums/topic/284048-345-brake-discsrotors/
It has been done before, it worked with good results on an R33 GTS25t track car. But to make it worthwile you really need to use an F40 or F50 Brembo 4 pot caliper as they take the 32mm rotor to start with. All the mods required to work with a std caliper makes it a bit silly (IMO), espcialy taking 2mm off its thickness.
it saves weight ,and will cool faster and the wall thickness is still as much as the gtst ones,just thought it might be an option but if its already been done it doesn't really matter
,thanks anyway
,thanks anyway
I dont think it works that way - loss of 2mm thickness equals loss of thermal mass, in turn the brake rotor will reach its upper serviceable temperature quicker for a given brake work. If my memory serves me right, R32 GTR rotor has 32mm thickness as new and unserviceable limit as 30mm. Also, I'm told that thinner rotor is subject to warpage.
Cheers,
Sam
that's correct. 32 GTR rotors standard are 32mm thick and wear limit is 30mm. the problem is the inner area of a thicker rotor will be larger than a thinner one. so as you take 2mm off the outside you are now closer to the inner vanes.
Really? Did you modify the caliper? When i slung the GTSt caliper over some Performance Friction 340 x 32mm rotors it wasnt the divide for the piston that was the issue, it was the outer opening of the caliper where the rotor enters and leaves the caliper that had a clearance issue with the 32mm rotor.
Cheers,
Sam
it will reach temp quicker,but it also cools quicker,and mine are gtst calipers standard 30mm rotor but i didn't try to fit 32mm rotors in
they may warp easier but discs only warp in extreme circumstances,and the serviceable limit is set by the calipers so the pistons don't pop out if the pads go to the metal
i have gtst calipers not gtr,and i took 1mm of each side not 2mm off one side
I disagree that the minimum disc thickness is set by piston travel - I'm sure you've popped them pistons out for overhaul and they have heaps of travel before they will fall out.
I suppose your argument is valid enough for mild brake application but if you go the length of fitting larger discs, calipers adaptors and machining the disc to fit the calipers size, you might as well do it right.
Cheers,
Sam
what if you took 1 mm off each of the pads?? disc would remain untouched and all of its properties.. pads wear, i cant see a problem with it.. if it scrubs on the caliper, machine the caliper slightly... no doubt that is what nissan did to gtst calipers to fit the gtr.
i think i'll do this next time
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
