Hey,
Im having trouble getting the correct belt numbers for my GT, Repco etc dont have a listing for the Neo GT and I dont want to end up with the wrong ones. Im pretty sure they arnt the same as the Turbo model nor the 33 Non Turbo... I could be wrong though.
I have Bosch belt numbers but they dont match up with the ones Repco have....
Any help would be good. :P
I need Aircon, Alternator/Water pump and power steering belts.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/
The belt numbers should be useful to Repco anyway. Belt 4TK910, for example, is also 40910 on the parts list. "4" stands for 4 ribs, and "910" is the length, and so on with the other belts. Have you priced them at Nissan?
I get my car back at lunchtime ... I peek under the bonnet and get my numbers. T and non-T Neo motors should be the same surely.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776105
Ah Ok,
Nah I havent called Nissan....
You would think they would be the same but they have different oil filters and stuff so I just wanted to make sure.
Im desperate, the one bird under my bonnet now sounds more like a jungle.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776139
While on the topic of belts, etc. Does anyone have the Gates Racing Belt Codes for the R33GTST? I am looking mainly at ruby here, cos of the place he got his from.
http://cgi.ebay.com.au/NISSAN-SKYLINE-R33-...p3286.m20.l1116
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776587
Just double check your stock belts first against what is quoted in that ebay link given by Penny. They did get one of my belts wrong ... but made up for it.
This Mico-V /Drive belt kit contains the following parts: 1x 4PK835R 1x 4PK865R 1x 4PK925R
I believe you need something like 1x 4PK865R 1x 4PK890R and 1x 4PK925R
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776653
gates??? more like goatse :)
Really?! Why's that?
Thank you :P
Thanks Ruby, its just that i don't want to go through what you did, as its going to be a few weeks/months before they get installed and if its the wrong ones, then they may not swap after that long a time.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4777065
just that dayco have a far more superior warranty setup if need be...also all the R&D that have gone into dayco exceeds the quality of gates belts....im not just saying this because i sell dayco....but from experiences with both products on my own cars
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4777972
Can you send me a pm with prices for a set of Dayco belts for my car? Also if you can get a timing belt too.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4778034
Replaced all my belts... and guess what...
ITs still F&%* Sqeeking! Tightened them twice now. Then thought there may be left over belt grip making the noise so I degreased the lot and it didnt help.
I am sooo over it.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4800576
I am sooo over it.
Shoot down to my place and I'll take a peek under the bonnet for you. Perhaps waterpump?
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4800866
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
