Ok so basically one of my cradle bushes has been leaking oil, and the car seems to feel really sloppy in the arse end, especially around uneven surfaces on corners. Is it ok to just get solid bushes fitted (and adjustable camber arms), or am I going the wrong way about this? I don't care about ride quality, I just want maximum handling improvement.
https://www.sau.com.au/forums/topic/284112-r32-cradle-bushes/
Yeah I was looking into the solid metal ones - a mate did this on his A31 and said it improved handling noticeably. It's also kind of important, since the bush(s) seem to be absolutely stuffed now (ie car feels sloppy in the rear all the time, getting axle tramp and a feeling of a loss of control when cornering too hard etc)
hows that.i had same problem in my a31.when i came on boost it felt like it was twisting the chassis.so i droped the sub frame out and sure enuff ithe rubbrs wer torn.i bort sum alloy locking washes NOT pinapples,chucked it back in and was all gravey.my a31 hd 383.3rwhp and it stoped the twist and was also running a locked diff.
so i would run wih the locking washes only take 30min to slip in as you only have to undo the subframe bolts enuf to slip them in
Ok so I ended up getting some alloy ones on Ebay, but it turns out that they are the ones which require dropping the subframe to put on rather than the 'slip on' type. The seller claims that they are a better long term solution than the slip on ones, but I'd thought they were all the same thing :S
just cut a section out the size of the bolt... it only needs to happen on the top rings and it doesnt not affect the effect.. i have done this on both my r33 and r32 and found the handling to be noticably better and the ride quality hardly changed. that is with solid alloy lock rings... not urethane pineapples.
Well as it turns out, I got the car looked over when I got new tyres, and it turns out that all the rear bushes are stuffed as well as some of the steering components ;) So the rear subframe will be removed anyway lol.
Do any of you suspension guru's know where the best prices on bushes are? I was thinking whiteline or something like that. Kind of annoying since I'd just gotten all the stuff to do the 100k service and now find out that half the suspension is stuffed too!
Well as it turns out, I got the car looked over when I got new tyres, and it turns out that all the rear bushes are stuffed as well as some of the steering components :D So the rear subframe will be removed anyway lol.
You can get Nismo one from http://www.nengun.com/nismo/suspension-lin...arts-gt-r-bnr32
Also this image will help you when ordering the bushes if you decide to go this way.
AU $ 304.71 including delivery.
I ended up getting a set of KTS Alloy Cradle Lock Collars since the guy I was dealing with on Ebay stuffed me around, one other thing, do superpro or whiteline etc sell complete rear end bush kits for Skylines? I've seen them for Falcondores, but not for imports :D otherwise I'm going to have to find the list and order it all piecemeal.
so I got a mate to attempt to put in the bushes on the weekend. However, whilst the backs went in no worries, there are bolts at the front which are rusted tight and are inaccessible by WD-40, do any of you boffins have any ideas on how to undo them? We didnt want to yank too hard on the breaker bar for fear of snapping the heads off the bolts and making it worse :P
However even with just the back ones in there was a noticeable handling improvement, but it's far off perfect.
Well as it turns out, I got the car looked over when I got new tyres, and it turns out that all the rear bushes are stuffed as well as some of the steering components :P So the rear subframe will be removed anyway lol.
Shakiel at feenin performance will get very good prices(trade) on the parts, and do a very fair price on the install. http://www.feeninperformance.com.au/?pid=servicing
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
