ok guys i need a bit of help, a bit of a brainstorm i guess and any help would be appreciated.
for the last few weeks i have been doing a few little modifications to my series 2 33gtst including 100 thousand service, new plugs gapped to 0.8mm, bosch 040 fuel pump, front mount intercooler, new plazmaman intake plenum and throttle body and a power fc which all needs to be tuned.
now heres where my problem is, on really cold mornings, like freezing cold morning, it has a missfire at idle and through the entire rev range, continues like this till it has reached just over operating temp and seems to clear itself and runs fine there after, now its not just when the engine is cold as if i leave the car sit all day and start it again in the arvo it doesnt do it.
so far i have tracked it down to be on number 1 cylinder and will be doing some more tests in the morning when i get back to work, so just wondering if anyone has had this prob or heard of it before, is it a tune issue, bad plug coil pack etc, any help or suggestions would be mostly appreciated.
thanks
https://www.sau.com.au/forums/topic/284134-weird-missfire-problem/
at a guess, it is going to be a spark or fuel issue (such as AFR's being out). it will be caused by the cold, dense air in the morning, and that is why it won't do it in the afternoon. and the reason why it stops as the car warms up is because the heat from the engine is warming the air up.
if you are only running the basic tune that was on the pfc then that is probably going to be more of the cause than anything. it isn't recommended to run on this tune for long. if the tune on the pfc was done before the bigger throttle body and plenum that that will be the issue. it will probably be running lean (cold air is more dense, so it needs more fuel to achieve the correct AFR)
thanks for the reply mate, yeah the pfc is only the basic tune i only been driving it to work and back so like 20 k's a day for a few days
an update on the situation
got to work this morning and changed no 1 and 2 coilpacks around, missfire still on no 1 cylinder
then changed no 1 and 2 spark plugs around and still missfire on no 1 cylinder
then lastly i put my noid light on no 1 injector and nothing, no flashing, tried on no 2 injector plug and it was flashing, so back on to no 1 and nothing
so the cause of the missfire, or running on 5 cylinders is due to no injector pulse on no 1 injector.......but why i still dont know
so te next step tommorrow morning is to swap the pfc for the standard ecu and see if the problem still occurs, if it does then i beleive i have a wiring issue somewhere, and if it fixes the problem then there is something wrong with the pfc/tune etc
has anyone else ever had or heard of this problem???????
Our neighbour's Holden Missfires on cold starts, i remember chatting to him (because he works with those cr@p-mobiles) and he said it was either the distributer playing up or slack in the timing belt or chain - (which makes sense because if you have slack in the fan belt, the sound goes away after about 2 mins of running - or until you re-tension it).
hey guys thanks for all those that had some suggestions for me, i found my problem this morning, so here is what was wrong
***The Connection To The ECU Was Bad***
and thats all it was, seems i had a case of a slightly banana like plug and wasnt making good contact on te lower pins of the ecu which just happen to be the pins that pulse the injectors. GAHHHHHH :D
so after all that it was a simple fix i simple just pushed the connector on properly and now runs sweet as
so just a little heads up to anyone that ever has a wierd problem like this one, check the connection to your ecu, especially if like me you have been playing round there lately ;)
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
