Hi All,
The next SAU dyno day is to be held at SST on Sunday the 7th of December, and we'd like anyone from SilviaWA or any other jap import who wants to compete to join us. You will need to complete the form and pay $30 prior to the event to be eligible. We only have limited spaces so get in quick. We're expecting to kick it off at about 10:30. We'll be having a lunch break and will be running a sausage sizzle.
There will be trophies for Highest HP 2L, Highest HP 2.5L and Highest HP 2.6L or greater. There will alos be an exhibition class where we're hoping to have a few very high horsepower cars make an appearance:D
http://www.tnet.com.au/~dantheman/Shooutou...mniform-SST.doc
https://www.sau.com.au/forums/topic/28419-sauwa-dyno-comp-sun-dec-7th-sst/
  • Replies 59
If you have sent you money and form in and your not on this list then PM me:D
Entrants:
Luv DR
Shuto-boy
REP003
MearCat
Jill200SX (SilviaWA)
Yoon Kang
DSTURBD
living backwards
Gavin (japSpec)
B_real (SilviaWA)
ND4SPD
jmp
Bully?
S13 Angel
DR30RS
I will not be running.
I just got a new clutch installed today, canna flog it for a short while....bugga!!!
Also I will come down to support and I will even pay $10 for steve to show me how to adjust my friggin bleed valve (sounds like a bit much, but thats how much I wanna support)
heck I dont mind still paying that $30 if steve will do me a power run later in the week or when I can clock up enough k's on the new clutch
i got sunburnt :cheers:
good to catch up witha few peeps ....... stoopid sun burn tho :(
Thanks for cooking the snaggers Cam ..... big thank you to SST and Paul for organising and the people that came down and supported the event :grouphug:
No probs Niz - farkin hot job it was. I saw quite a bit of sun myself.
Good work by both the postwhore and the SST boys. And thanks to all those who came along.
Paul - you going to post up a full set of results?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
