  • Replies 716
Posted Images
haha 36mm socket, and a breaker bar long enough to move the moon? Some of those nuts are a f**ker to undo, and I keep forgetting to undo the hub nights *before* I take the brakes off.
If you are stuck I have the super multi geared nut undoer - it puts enourmous torque on the nut
nuts
anyway the front end is done
swapped the cradle and brakes to a more user friendly one also removed some weight where i could!
the stopteck's are slighlty lighter than the brembos as well whick is a bonus
fits nicely
will give her and alignment then its onto the rear cradle
just waiting of diffs from the barron and she will be back to gethere post haste!
then cage time
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
