  • Replies 716
Posted Images
took jennas car to wakefield
it was cold
this truck tried to drift on the freeway
rolled once
in other news i f**ked of the china radiator and put a stock gtr radiator and jennas car no longer overheats
however we warped her rotors and killed the brakes again
yea baby
jenna was famous
unique cars wanted a photo and some story
he even wiped the bird shit of the window.. nice bloke
some dude with money thrashing a new car
yea baby
then we got drunk and had a party
and i got a new shirt that is awsome
jebus?
I will never do this job again.........
Ever, its a massive head f**k getting everything true and square.
Here is a few crappy I phone photos of pete's rear end. Everythings been seam sealed and roughly painted, needs a coat of under body tar to finish it off.
The rear pins had to be machined up and the chassis modified to mount them, front of the subframe has been cut and shut with new solid mounts machined up, cage will penetrate the floor to add additional strength but the whole thing is done with 4130 molly plate and bar so its bullshit strong anyways.
There is also a rose jointed rear steering set-up for it which is very nice.
Better photos tomorrow in the light old mate
Here is the new and mildly improved rear steering arrangement for Pete's cars
The pins are machined 4130. They pretty much push in and bolt to the original upright removing the horrid factory ball joint on the outter. The arms will remain factory for replacement sakes and 5/8th's rod ends are used for the outters.
The pin straight out of the lathe
The parts needed for the ouuter
Assembled quickly in the upright
Plans are to sell them as a kit shortly
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
