  • Replies 716
Posted Images
  • 4 weeks later...
ummm....I just got the entry list for Eastern Creek.
2x GTRs...Handley and Eedens......where is Carruthers? I heard yours might be running.....
BTW first time there have been 2 GTRs on the entry list since Phil Coles won the champs in 05
good to see all r32 shit heaps have dagging lip
dont know if i will make the frist race but it will be 40000000% there for number two
in more important news
the r32 gtr race car runs
do not buy a car of ( who i bought this bucket off.. if you read the thread you can find out who)
bonken terminals in the Fuel pump modual (the plastic thing that goes into the tank on a gtr) funny part is they obviousdy found/discovered THE problem tryed to fix it and f**ked it even more........ then decided to sell it lol)
on of the terminals broken
broken engine wiring loom
dodgy rewired fuel pump
so any way
it runs
first track day asap
yea i will buypass the thing
just wated it running perfect before i started stripping shit out of the loom so i had a clean base to start with
neil im sure it will catch on fire( specially after auto pro gave me non efi line for the fuel line. lucky i found out before it got freaky
  • 4 weeks later...
