nice one shagger! pull ya finger out and get the car done. don't let low oil pressure stop you like it does dundan.
if you need a hand give me a yell. can't promise I will do up your wheel nuts properly, but if a wheel flys off I promise I will say I did them up properly....
  • Replies 716
Posted Images
  • 3 weeks later...
Well it had a massive blown gasket against the head number 5 inlet.
Fixed that up now the engine is ready to party.
Not sure bout the rest of the car though......
We decided last night that duncan and Petes car can both go into the naughty corner and live there
