  • Replies 716
Posted Images
Believe it or not pete's car is not that bad.
It's sorta done okay, kinda, in some ways....
His got it back was going to the dyno straight from here so I'm sure he'll post up how it went, if it went.
yup just got back
tops work brad!
champion
252rwkw at 13psi
so should do alright
did run 260+rwkw but was pinging and shit
pants of to brad for the tops work and hitman for the tune
excellent result pete...once the boost restrictor is on you will need to drop to 12psi but you should still be 240kw+
why pinging on higher boost? was fuel pressure OK? or just injectors running out?
It's probably still got the same fuel in the tank from when he bought it!!!
Wouldn't surprise me one bit ;)
We pretty much preped the whole car front to back in a day and replaced the blown manifold gasket.
All fluids, alignment, brakes, attessa repairs blah blah.
yeah that curve looks excellent considering that everything is standard.
and good work brad tidying it up the car so quickly.
good luck for the weekend....2 hours racing is a hell of a shakedown for a brand new car. Mine gets through a tank of fuel in about 55min so keep an eye on fuel surge from about 50min
You forgot to mention that he needs to remember to put fuel in the car to begin with... ... ...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
