Owners age poll
385 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I assume this isn't a photoshop, as the car is russian and they are just crazy enough to do that.
That car needs to be confiscated and the guy sent to one of those russian places where no one ever returns...
I reckon the car is stolen in EU somewhere and probably just driven in Russia like this - "what Audi mate, its a BMW, can't you see, here, go away take 100 Rubles with you" :)
Oops, just noticed that my poll doesn't account for 45-50 year olds - oh well, put the age that you feel like, if you are in the missing bracket. I know some people in late 40's that feel like 25 year olds but some look and feel like they are 70 hehehe.
In that case your 50+ group should read >50 not 50< or it is the same as 45-50.
cl 65 is BI turbo, not twin turbo lol.... 500k new, 200k after 1 year and 5000-10000km on the odometre..... get a year old one lol
BI = 2, so bi turbo = twin turbo, they both mean the same thing (forget parallel and sequential)
I know of a family friend who has one, but he's over 50.
Theres a bloke that went to my uni who owns one awell, he'd be in the 25-30 bracket. Won lotto...
why does it say i have voted on this ? why would i vote on this
If you check the result the poll recognises this as a vote, not a valid vote though, null vote. Its just how its setup, nothing with me dude.
I would have voted, but since im not proper enought or lack of $$$ for one, so I didnt vote, as for people aspiring to euro cars, just by them new and replace them every 3 years, but if I have to buy a second hand euro atm, bang for your $$$ would be a 05-06 SL55 something about that model.
I reckon the car is stolen in EU somewhere and probably just driven in Russia like this - "what Audi mate, its a BMW, can't you see, here, go away take 100 Rubles with you" :(
*drumroll*
and the plates belong to an 850i
lol i know that, i'm just making a point of it lol
  • 11 months later...
51
Property Developer
Had the Mercs, BMW M3's & M5's, Corvettes.
Porsche's are a cliche!
Ferrari's are passé and can only be red
Astons and Massers are very pretty and very slow
My new black GTR 35 is simply humiliating all my poser mates!
The only car after a GTR is either the next R36 or, Pagani Zonda or the next Lambo.
Kymbo
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
