The RED car with thr R31 GTS front bar is built by Randy at Nissco in Bayswater VIC
It has a 2.2 liter, meaning bored out with bigger pistons, its NOT a 2.4,
Call randy, say your interested in brining it back to VIC and he will sort you out, and let you know the story how its one of the only cars they had to chain down on the dyno cos as it came on boost so hard it wou;d try and jump off!
I say go for it, I wanted it a few times myself.... it is built well and obviously can take it.
  • Replies 80
Thanks man ill do that
KN R30
So Can a South African car be registered here in vic? i guess thats really all i care about right now can i get a road worthy and register this car in vic? also what paper work does the car need to have with it to make this happen?
im well aware its to dear i dont need to be told this again lol
Registration should not be a problem as it originated in Vic, but I would assume, if proof of registration interstate was provided, it would nearly be just a matter of going through the motions to make it comply with the particular states parameters.
Just try to deal with the guy & if you can cut a satisfactory deal, go for it, as at the end of the day, there is only one person that has to be happy and that is you!
Parts really aren't so hard to find, just a tad more expensive these days due to age & importing from Japan.
I can't understand why groups of guys/gals don't get together and form buying groups to get the bits from Japan they want and therefore combine the postage to save a little money.
Cheers, D
:) With the current seup it's running now? VG30 turbo and all?
My mates 2.1 FJ when it was running a VG turbo didnt come on boost hard at all, was smooth as and already building boost by 1800rpm completely run out of puff by 6000rpm though
:D With the current seup it's running now? VG30 turbo and all?
im not sure, it was 4 or so years ago...
but it seemed mental to them cos they built a heap of L18 powered 1600's and the occasional Z18et... now they do SR20det on a nearly monthly basis
i took a ride in an evo they bult for rally events, bloody hell i nearly shit myself it accelerated so hard, and the brakes were that good i almost got winded!!! the sound of antilag blap blapblap BRROOOOOOOSHHHHH and 4 seconds later your at 100km/h and climbing
i luv industrial estates!!!! :)
Well i brought it !
ill just say i paid less than 5 for it so im happy ! should be a fun drive back from SA
How long will that trip take me?
Congrats Marc... I hope it turns out to be a good purchase.
Adelaide to Melb is 8 hrs I think.
JH
It was definitely an L-block (the FJ's all had LH exhaust outlets), The grille is also from an S2 GT/TI, so KN-R30 makes sense. I'd be pretty disappointed with 150rwkw from a 2.2L w/VG30 turbine & intercooler though...
Hopefully it proves to be 'just right' for what you're after, IMHO the price is 'ok', but I'd be expecting to find some skeletons in the cupboard!
I would have thought 150rwkw @ 8psi was pretty good? i see yours has a list longer than my you no what and its only got 140rwkw? im not sure about these things
Thanks input Ben
I'll be the first to admit that dyno numbers don't tell the full story and we haven't seen any graphs for your new car. But with 2.2L and decent management I'd be hoping for nearly 150 at standard boost. Yes my car 'only' has 140 (it was 95 when I took delivery of it), but it's internally standard, and running about 10psi through the standard turbo.
Things we expect from you:
Lots of photos
A report on the car's condition
registration into the 'registry' thread
:3some:
They don't come up for sale that often, so this kind of thing is a special occasion!
Good for you Marc. FJ22 is my dream engine... Are we going to see any power upgrades in the near future?
Also did you find any decent projects about? I'm sort of in the market for one.
Only cosmetic stuff to begin with new wheels, front, (iron mask) side steps, and two tone paint etc it will look great you will see lol
Lots of photos
:D
I spoke to The guy that built it he said its very restricted currently cause of building it to pass road worthys he says with very litte work (big free flow exhaust, more boost, its a 200rwkw car easy (his words)
  • 4 weeks later...
just a brief update on this car
here it is as it was brought by me
and here it is after iv put wheels and done some paint only started putting on the iron mask front.
now from here im going overseas so there wont be much more till Febuary next year but i have several more bits to go on
-Tein coilovers (ill make it much lower)
-Gtr front brakes
-side skirts
-front skirt
but just wanted to update what do you think so far?
Not bad. did you paint the lower section the correct metallic blue, or black?
I don't know how much lower you'll want it - mine probably rides about the same height as yours and I can only just get a conventional trolley jack under it...
(plus the rear neg will start to get unmanageable)
lol black!
also much lower! i will set it with the front wheels level with the gaurd and the rears will sit under!
like they do with them in japan! there is plenty of room right now under it
Looks 100% better :(
I had to raise my car as it was too low, most of the trouble I had was that the sump sits lower then the cross member, as does the very bottom of the gearbox. So both copped a bit of a beating. Also my radius rod mount bottomed out over speed humps and cops really didnt like it :) There was no thought put into handling like this though as the roll centers were way out of wack and so on. But all of which has been sussed and it is probably a good inch or 2 higher
Edited by DR JOSH
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
