The Make An Offer Sale (part 1) - R32 / R33
Hey,
Starting to clear out the spares. Going to do this in parts as its easier to keep track.
All the parts are in the pictures on my photobucket acc:
CLICK ME
Have a look through the photos, see anything of interest and make an offer. Basically, if you cant base a price - search SAU, find what people are asking, make it abit cheaper make the offer inc. the link and you'll find ill say deal, really need to clean up the shed. If stuff dont sell ill let it go for FREE (later down track) otherwise i'll offer it to the scrappo or the dump.
Im a real fair dude, ask others who i traded with and am always happy to help out a fellow skyliner.
Parts include stuff like:
- Interior Trims (ranging from good to poor condition)
* Dash's (32/33)
* Boot trims
* Door / Boot Seals
* Glove box
* etc
- 32 Rear bar
- 32 Driverside Guard (89)
- 32 Cross members
- 32 LCA
- 33 5stud Front hubs (with lines etc)
- Random Brakes (think s13)
- Assorted Underbonet Pieces
- Gauges / Interior Bits and Pieces.
Cheers,
Dave
  • Replies 41
forgott to add
- turbo (rooted) worth an offer of $10 or so to take it apart and lean how they work.
- gab rear shocks
- stocko shocks
- rotors ( r32 fr/re 33 fr)
- dump pipes
- suspension parts
- subframe (bushings removed, needs paint)
- Steering racks ( for parts or rebuild)
- sway bars (upgrade ya s13)
- 33 aircon gear (replace a rooted fan)
- 32 tail lights (minus trims)
- 32 indicator light
- 32 aircon controller
- 32 stock fuel pump, fuel covers / flaps & rubber
- brand new 52mm gauge cups, twin Gage A pillar
- 33 steering wheel inc airbag (make an offer, even if you just wana blow up the airbag)
hey just wondering how much u have got on the drivers front indicator and the a pillar 2 gauge trim. Is the trim for a 32 or 33?
I'm in morayfield and is there anyway to organise a pickup.
thanks mate
thanks mate
that gauge trim came from a 32, and i think it has a small crack. if its rough ill throw it in with the indicator.
cheers,
Dave
will u take $30 for the drivers side indicator? whereabouts are u located?
sure. want that dual gauge pillar pod for nothing with it?
westside 5mins from kenmore
cool man thats sweet! give us your number and we can sort out a time to pick them up. my number is 0406 459 669
thanks mate
hey man. just wondering if that was you calling me today and yesterday. if so your number came up as anonymous and i cant call u back. so i can come pick it up tomorrow afternoon/evening. so gimme a call with your address and i'll come get it
will ya take 30 for the steering wheel?
sure mate. 0420 855 181
just sent ya a txt then containing address.
dont have drivers and passengers side seats and rails for 33 do you?
sorry mate
hey man just wondering if u still have the steering racks? If so is it for an r33? as i'm after the power steering solenoid located on the rack.
yes i do, but not that i wana get rid of, will a 32 one fit?
PM'd
32 tail lights cheapest?
$50 bux for both?
33 5stud Front hubs cheapest?
um usually they got for 200bux for hubs. ill say $200 as they are in the photo, with the braided lines on them.
PM'd
thanks
Edited by 32_Dave
hey man, i was just wondering if you would have any of these things for a r32
-the drivers side kick panel
-the centre ashtray (the one under the stereo head unit spot)
-a good condition centre console, and
-drivers side quarter glass surround.
Thanks mate.
Thanks mate.
ill have a look.
im sure i have the kickpanel and the ashtray.
the drivers side quarter glass surround is appart of the actual glass so ull need a complete item. and no u cant have mine :(
how'd u go with the parts man? Have u got them?
pm'd ya mate
sorry ive been the typical slack seller. i preffer people to pm me as it reminds me.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
