get a copy of DVDShrink 3 Beta
get Nero Burning ROM or Clone DVD (I prefer clone DVD coz it allows Disc labels up to 30 characters)
rip with DVD Shrink and then burn with the other... done.
This is the simplest way I've found to explain for n00bs to DVD burning...
if you wanna mess with IFO's VOB, demux and remux and also combine multiple DVDs onto one, then ummm read up at dvdrhelp.com and doom9.net
if you really have no clue and u'r around my area come over n i can sho u how to do it
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-591579
Get DVDXCopy. It is undoubtedly THE easiest way to copy dvd movies. Forget arsing around with multiple programs. It will get round most copy protection, and automatically shrink larger DVDs to fit onto standard media. All from one simple click of the "start" icon. Easy. Even my mum can work it.
NB: you can usually find the lastest version and a crack on Kazaa
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-593217
DVDXCopy also happens to be the most butchered app out there, the compression engine is one of the worst I've seen, makes it all nice n pixelly compared to the other methods.
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-593255
What about copying playstation 2 games?? is it the same method?
They're even easier..don't even take up a full DVD most of the time... i just just use nero to do them
Is there any difference between DVD-R and DVD+R??
DVD-R is a cheaper.. thats about it in a real world sense, and I guess slightly more compatible with more devices.
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-593639
Only in the devices that read em, they're both the same capacity and around the same speed at burning. -R was popular for a while (more players can read -R than +R), and then all the +R burners started supporting -R as well so its hard to differentiate these days
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-593649
I have tried the dvdxcopy and it didnt work, well the program said that it had completed the dvd but when i went to play it, it didnt work and the computer doesnt even reconize the file types on the dvd now.
Any how were are you guys getting your nero 6 from are you buying it or has some one found a keygen that works?
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-593703
As for playstation2 games...best thing on the market to back up your games....ALCOHOL 120%.....check it out.
As for DVDs
Xcopy Platinum is the way to go for easy of use.
CloneDVD Can now do the same as Xcopy.
DVDShrink-it will do just that as well as basic re-authoring.
IFOedit and other will allow for more changes to movies...etc.
Also for DVD mastering Gear Pro 6.05 is great.
Thats my 2cents
https://www.sau.com.au/forums/topic/28519-dvd-copy-how-to/#findComment-593935
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
