I went to pick up a hi flow malpassi rising rate regulator today :) but got a shock when I saw it. :alien:
I thought it could fit at the front of the fuel rail, and replace the factory one but I noticed the following problems.
1 - the malpassi has 2 inlets (I think) and one outlet on the bottom, as well as the vacume line whilst the little factory unit has one inlet, and one outlet. (What do I do with the 2nd inlet?)
2. how do you mount it to the end of the fuel rail? the fitting for the original is a screw on item, and the fittings provided look VERY incompatable.
Any instructions, photos or information would be greatly appreciated.
dude i got one of these. fuel goes in at the bottom and out of the the outlets on the side. vac on top and plug the other one up. on my rb20 it has the hose going from regulator to the side of the plenum and then another hose connected to the std regulator.. the std one has no vac.. this is how i bought the car.. seems to work fine.. but latley my car is chuggin and shit when idleing at anything belove 1000rpm.. lights fade, car nearly stalls, ONLY on idle.. i belive this is cause of the fuel regs pressure is to high.. so make sure you get it set up on a dyno or something.. my car blows a fair amount of flames/pops n stuff so i guess its too much fuel being unused.. but yea..there you go.. hope this helps.
Hi,
Its very simple.
1, Lets say the top of the reg is the section that has the vacuum nipple and adjustment
2, The holes in the sides are fuel in and fuel pressure gauge. If your not using a gauge then you must block one of the side holes off.
3, The hole in the bottom is fuel back to the tank.
4, Your original reg is bolted to the rail with a vacuum line and fuel hose attatched to it which if you follow it goes to the tank.
5, The hose coming off your original reg you need to cut some where, where you can mount the Malpassi reg. This hose has to join the original reg to the side of the Malpassi.
6, The other end of the hose that goes back to the tank pushes on to the bottom of the Malpassi.
7, The vacuum line for your standard reg is where you get vacuum for the Malpassi so just get a t piece and t into it leaving the standard one connected. This is so you still have a fairly smooth idle as just using the Malpassi can create idle problems due to too much pressure.
8, You will need to set the pressure on the malpassi while the car is idling and the vacuum line is disconnected on both the malpassi and standard reg. Set it to about 40psi. Then hook both vacuum lines back on.
9, A mounting bracket bolted to the rhf strut bolt is generally the easiest to put it for a skyline. Enjoy!
Michael...
Yes you can have vac to both regs. Doing this will give you standard pressure at idle meaning smooth idle. If you are running high pressures on the malpassi and dont have the vacuum line connected to the standard reg you might have idle problems such as stalling and very low idle.
Michael...
Not too sure if this point is valid but would likie some confirmation on one thing, if your installing the malpassi to increase fuel pressure on the rail shouldn't it replace the standard one? if the standard is there wouldn't it override the efforts of the malpassi?
some ideas would be good!
Cheers
H'Day EnricoPalazzo
I was hoping for some pics aswell, maybe over the weekend.
Last Friday I was just dropping in to say G'Day - couldnt realy go on the cruise as my wife and kids were all at home sick with the gastro bug.
Once I get the fuel pump, regulator and a dyno tune though I'm looking forward to some good cruzes. Hoping for in excess of 200 RWKW :)
If you put a malpassi with a higher base pressure after the stock regulator then you will have higher base pressure through out the whole system. The stock regulator will open at say 40psi but the malpassi is behind it is maintaining say 50psi. That means that the stock regulator is just sitting there causing a restriction in the fuel system.
Anyone got rich idle problems when running a bigger fuel pump? This is because the stock reg cant flow enough fuel to maintain the 40psi (this is just an arbitary number) base pressure and hence the pressure behind the injectors increases and they squirt in more fuel for given opening time. When you are driving, there is more fuel being used by the engine and so the regulator doen't need to flow as much to maintain a set pressure so it's ok.
By fitting a rising rate malpassi you can eliminate this problem by setting the standard base pressure, and hence get good idle mixtures, and as it has a 2:1 rising rate (from memory) you get additional fuel into the engine when you are on boost which is where you really need it.
If you are running a higher base pressure then you will require tuning to get the idle right but due to the higher pressure atomisation of the fuel mixtures will be affected so you may never achieve a factory idle.
Just my 2 cents.
Dave
I have tried to find a fitting to replace the stock regulator all day but had no luck. Could you just drill the internals of the orignal fuel reg out at all and just keep it on to save getting a fitting made????
Please let me know asap as im having a lot of fuel dramas.
thanks
Jayson
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
