Blits bodykits on the gold coast have the mould to make one.
Approx $450
Pretty good quality. I would not recomend the others sell them in Adelaide.
Make sure you read this thread
http://www.skylinesaustralia.com/forums/Fr...ml&hl=blits
https://www.sau.com.au/forums/topic/285309-help/#findComment-4791755
thanks for the responses. thanks for the heads up on that thread darren. i have had dealings with the mentioned place before and the quality was pretty poor so i will steer clear of them i f i can. ill contact blits about the prices plus postage. was hoping to find someone reliable in sa but cant be picky i guess.
your cars looks aweseom darren!
https://www.sau.com.au/forums/topic/285309-help/#findComment-4791913
Hey mate if u need i have a standard bar here altough it has a crack in it. If u want just to get u through regency
thanks heaps for the offer. i have to get a new front bar for it anyway so ill have a look for a bit. i can still drive the car around i jsut cant change the plates to sa plates. thanks heaps for the offer again and ill pm you if i the offer is still there when i cant find a bar haha.
https://www.sau.com.au/forums/topic/285309-help/#findComment-4792071
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
