Yes they are the same and diret fit, can you elaborate on the options? as there are plenty around for R33's but i havent seen one for an auto yet with the built in cooler/warmer in the radiator.
Racing radiators won't make your car go faster. To elaborate i upgraded the radiator on the car i just wrote off. In the new S1 which i have rebuilt to the same specs I am still using the stock radiator and have done two track days with no sign of overheating. If i have to replace it I will go to a radiator repair shop and buy a slightly thicker one for about $200. I wont be going to the speed shop to buy a Japanese one for $900 or even $300.
i have a s2 and i am running a cooling pro r34 radiator i made my lines that go in to the radiator go to the second trans cooler but if u have upgraded ur stock one just loop the lines up that go into the radiator if u need any help i can explain it to u over the fone just ring me
myles 0432355971
thanks for letting me know it wont make my car go faster lol, i'm just worried about it overheating when i get a front mount in our hot Perth summers just a precausion really for pice of mind, i might just get mine flushed really well and see how it goes. I may try a radiator repair shop also like you said not a bad idea.
Edited by horrace
ah ok didn't realise there were no auto ones, but figures i guess.
Interesting, this line on an ebay page advertising a Koyo aluminium radiator for R33 GTR:
"Koyo aluminum racing radiators are made for manual transmission applications only, automatic transmissions will require an external transmission oil cooler"
So I wonder if the water exchanger is really necessary? I'll have a chance to ask an expert tomorrow, so I will do just that :D
Yes that's pretty much what I was told too; if upgrading the radiator you have to run a complete bypass setup (big transmission cooler I think). This was not desirable to the expert I spoke to because it takes much longer to bring the transmission up to temperature without the radiator loop which is a heat exchanger that works between the transmission fluid and the radiator coolant. There was no mention of excess wear however; the transmission has a 'warmup' mode where it is privy to the coolant temperature, cold-run etc. and will change the shift mappings/lock out the lock-up solenoid (lol)/lock out the overdrive solenoid etc until it reaches operating temperature (about 60 degrees). This is what you normally notice at startup and for about 5 minutes of driving on a cold morning. Without the heat exchanger in the radiator this may last say 15 minutes or thereabouts. So no 4th gear or overdrive and a sluggish transmission for 15 minutes every start.
yeah that would be hell gay waiting 15 minutes for overdrive since im on the freeway in 2 mins then its 25 mins to work lol. I think im just gonna rip mine out and get it a good flush ey, i was also wondering if something like a R34 auto radiator would be any thicker and direct fit? something to think about.
BTW since i put in my bigger davies craig cooler it definately takes longer to get overdrive, just something i noticed from the extra cooling.
Edited by horrace
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
