ITEM: Apexi V-MAX SPL RB26 2.9L (RB29) stroker kit (crank, rods, pistons)
TO FIT: RB26's
CONDITION: Excellent - Came out of a display engine from an ex-Apexi power dealer in Japan
PRICE: When new this cost over 1.2mllion yen ($18KAUD). There were only 30 of these kits ever made and this is the only kit I am aware of in Australia. I am asking $11,000 or near offer. SERIOUS ENQUIRIES ONLY Do not waste my time or I will waste yours.
PAYMENT & DELIVERY: Cash pick up or direct deposit; postage extra
CONTACT: via PM
PICS: on application - do not PM me just to see pics if you are not interested in buying.
Very intersting bit of gear you have there. Can you share some of the details of whats in the kit, size of the crank, rods and pistons etc. There is such a small amount of information around about this kit, and what there is is all in japanese.
87.3 x 79.4 = 2852cc
Rods a HUGE but not heavy....around 520grams with the width of the H-beam around 33mm fro memory.
The kit is still packed away so I will take it out of storage and take some pics as there are a couple of serious buyers.
Charlie, is there any stroker kit you haven't had? Have to start calling you the stroker king.
OS Giken RB30 :laugh:
I love my Apexi gear though. Unfortunately, this one must go as I doubt I will get the chance to use it anytime soon.
  • 6 months later...
  • 3 months later...
  • 5 years later...
hi mate, look ive been looking for this kit for a while, i realise the last time it was advertised was about 3 years ago, but if it is available i would love to come and have a look at it.
thankyou
0422816917 please text me or pm me.
Nick
thankyou
Nick
ahhh, so now you wanna stroker hey lol
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
