as the topic suggests. does overclocking mess with the voltages or anything to do with the HDD? mine was only 5 mnths old and totally died. to the point the comp wouldnt boot without unplugging the HDD. even tryed it in a friends comp as the slave, and it wouldnt boot either.
thinkin its had an epic brain fart, and just shorts anything it goes near
ideas?
itsa 750gig seagate barracuda
https://www.sau.com.au/forums/topic/285396-overclocking-and-hard-drives/
just talking about overclocking the cpu ram etc, not the drives. just simple stuff.
thanks D C, thats what i thought.
What firmware issues? i havent seen anything about it, got any links? and wtf, did i just send away a perfectly good HDD?
it worked great for 5 months, why would it change over night? and why would it stop any other sata drives from working?
i am confused
Nah it was every single 7200.11 drive with the old firmware
They did fix it of course...
But as he said it was about 5 months old in his post & that fits pretty nicely with when the problem (5-7 months old now)
if this is referring to the servo lock issue, it is for hdd codes ending 333as/340as for the 1tb drives. there was also an issue with early 1tb drives where the pcb fails. unfortunately this was on more than one of the factory fw releases so it made it hard to pcb swap. the newer drives ending 528as havent had any come back as yet.
depends on the reseller. if you shipped the unit direct to seagate, it is a brand new replacement. they generally dont hold old stock. but as for the reseller, it is hard to say. post the details on the drive and i can get you some more info.
i went thru umart, but the did charge me the postage to and from seagate, so i'd assume it SHOULD be straght from seagate, but who knows really
it seems newer details as follows
barracuda 7200.12
ST3750528AS
750gb
firmware cc35
date code 09517
unfortunately i dont have the old one to refer to but it does seem newer
and i couldnt find anything relevant to this drive on the seagate site
Edited by boiracer
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
