Hi everyone.
Time to let the rotary go guys. im starting my electrician apprenticeship next year and will need to buy something more usable e.g.vy ute
also open to trades cash my way
down to details:
POWER: 232RWKW 16PSI (240rwkw 17PSI)
TUNER: DALTON AUTOMOTIVES (CHRIS)
PRICE: $14,000 ono
MAKE: MAZDA
MODEL: FC RX7
YEAR: 89'
REGO: DECEMBER 09'
RWC: NEGOTIABLE
contact: PM or 0431324692 (you may need to send sms as i cant always answer the phone)
RECIEPTS OF EVERYTHING WILL BE INCLUDED. E.G. ENGINE REBUILD, TUNE, EVERYTHING!
Engine Modifications:
please note: i spray canned nearly everything in the engine bay black lol (wanted stealth look ill put photo up soon)
-MICROTECH LTX12 (LATEST MICROTECH ECU)
- 4X BRAND NEW BOSCH COIPACKS + new relay system
- NEW LEADS & NEW ECU LOOM
- Brand new bosch 023 600hp intank fuel pump
- 550cc primary and 1700cc secondary indy blues injectors
1> Fully rebuilt engine (AROUND 15K OLD) - rebuilt promaz
2>'Tuff stuff' race seals
3> Heavy duty exedy clutch kit
4> BRAND NEW ATR 45 TURBO WITH TR43 FRONT (480HP RATED)
5> custom oil and water lines
6> stainless steel manifold
8" 2.5" INTAKE PIPE AND POD
9> Knight sport fuel cut defender
10> OIL CATCH CAN
11> Front mount intercooler with custom piping
12> Custom 3" dump - front and cat exhuast & 2.5" catback exhaust
13> front mount oil cooler
14> master and slave clutch and brake cylinder and lines (all reciepts included.)
15> starter motor & relay system
16> resprayed lower intake and upper intake manifold
17> all new vacum hoses, clamps, radiator hoses
18> new exhaust and inlet manifold gaskets and seals.
Suspension:
1> Cusco zero, hieght and camber top adjustable coil overs all round
2> new Solid engine mounts
3> s14 / r33 rims sprayed hyper silver (FRONT)
4> 18" X 10" WIDE +13 OFFSET VS - kf Shadow chrome (REARS)
Interior
1> New 5x mechanical Defi style 60mm gauges
Boost (bar version), air fuel ratio, water temp, oil temp & 10,000rpm gauge. - controlld by switch in cabin
2> aftermarket black steering wheel
3> STANDARD GEAR KNOB
4> drift handbrake button
5> Sunvisor DVD player.
6> brand new jvc headunit mp3 etc.
7> 4" speakers front
8> 6" speakers door cards
9> 300w amp
10> 800w sub + ported box.
11> New GT3 Seat cover front and rear
Exterior
1> Resprayed Jet Black
2> standard original s5 bodykit
3> HOUSE OF KOLOR GOLD PEARL
5> spoiler removed and holes filled.
https://www.sau.com.au/forums/topic/285551-240rwkw-rx7-fc-series-5/
shit question but...how many km's you get out of a tank dude?
I got your msg about the swap, and i love RX7s, but it'll be a daily driver, so dont wanna be spending 100 bux a week on fuel
around 350+kms city driving
450+kms highway
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
