From a couple of days on,the stag been feeling a little slow when I accelerate from a complete stop,it feels like it takes a couple of secs.then the revs go up ,the turbo starts to boost an everything goes normal ,until next stop...
Anybody had suffer that before???Any idea or info is welcome...
https://www.sau.com.au/forums/topic/285565-stag-feels-slagish-on-take-off/
ditto.
manual - slipping clutch
auto - bands need adjusting / need a service with new trans fluid
worst case, the torque converter is on its way out.
to add some humour 'slagish', does it spit a lot of slag at other cars :)
i know you mean 'sluggish' ;)
Ok...sorry for my mistake...my car is a bit slug going out the lights...it's auto,and took it for a ride on tiptronic..all felt ok...
BTW where are you in the Se Burbs,Stagea _Neo?Good to see more stags in this side of the planet :)
Do the series 2's have a cable throttle body or drive by wire?
I have a similar issue with the M35, the ecu isnt giving me full throttle at low revs, it opens fully at around 3000 revs. I am planning a manual throttle conversion, I just hope the ecu doesnt get upset.
Scooty - mine is the same ever since the highflow was put back in. Notice it quite a bit - especially when cold! Hit 3,000 and it is a treat
Are you using a boost controller? If not try bypassing the solenoid with the ten minute boost mod (post #40):
http://www.skylinesaustralia.com/forums/Ja....html&st=20
Or a new set of copper plugs
Yep in the se burbs, near the burv.
Apparently there's a silver s1 or s2 near nunna swimming pools, my mates keep thinking its me :). Other than that, black s2 down Highbury rd recently.
Hardly see any stags out this way.
Back on topic....
Another thought is the vacuum modulator on the trans itself, get under and check for
leaking/cracked/loose hoses. (im not sure if modulator is correct term)
Scotty nm35 - nup cable accelerator, no drive by wire.
RBRyan - possibly in snow mode and the light not lit up at the switch on the console?
Or maybe the wires under the console are loose where they connect to the
snow mode plug?
Kidafa - Never known a trans ecu to have limp mode as such.
The main ecu yes. Anyone know how much the main ecu can
change the way the transmission ecu operates?
ie. shift point or engaging full lock up on the torque convertor.
Kiwi - Probably not advisable to increase boost pressure if there is an underlying
issue. Might make things worse.
ie. if it's the torque converter on the way out, it may make it fail sooner.
Trans ECU can go to limp mode if a shift solenoid is playing up, they will lock out of gears etc.
Take it to RVO, get them to plug into it for diagnostics... cheap insurance IMO.
I am in Toorak, work in the city, am out to mt dande a few nights a week, and geelong once/twice a month... See a black stag up mt dande a lot lately.
Do you guys get an indicator on your dash that you are in Snow or Synchro mode?
On the M35 you get the 4 wheel symbol with the drive shafts linking them to show you are in either mode.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
