hey guys
yesterday morning, went outside to find my mums car has been broken into AGAIN
nothing stolen, just rummaged thru the whole damn thing
im puzzled as to how the f**k they got in there without breaking anything because once again.
the door was just open and im adamant i had locked the car the night before
just be aware that this shits happening in the northern burbz more frequently now
10-20 seconds with packing tape and you're in. Not hard really.
They were probably there for all of 1-2mins.
Get an alarm.
please explain
it does have an alarm. thats what baffles me
and its not an old car that would be easy as f**k to get into
its an 05 territory
please explain
its an 05 territory
Go talk to an racv guy, they can get into anything, obviously someone has learnt how to do it.
As for the alarm, maybe you didnt turn it on, and if cars are getting broken into that much in your area maybe you should leave them open, leave nothing in there so after they go through shit they will leave without breaking a window to get in.
please explain
its an 05 territory
A Ford? :)
Fords are one of the hardest cars on the market to break into.
unless
They have altered the door locking mechanism to the fowlcans... if they are using a different system then ok fair enough. However if the same certainly one of the hardest systems to get into.
You left the door unlocked IMO, if you can't be sure of locking it.
Do you know if the alarm even works? Have you tested it out?
A Ford? :)
unless
im 100 % sure the doors were all shut because the car will not look and will start making a funny beep noise if you leave a door open and try to lock it
alarms working but i suspect its faulty so were gona get that checked out
gfs parents had they're new territory broken into this year aswel in glen multilevel carpark, alarm didnt go off either. No sign of forced entry or nothing.
.Ive seen RACV getinto a mates import...took him about 20seconds and nothing even close to damaging the car.....pretty scary actually to know they can do it so quick and quietly. specially if they;re telling family members how to do it who tells a friend who tells another friend... n so on.
Well, i'm in the South East Suburbs, and generally we've only had 1 car broken into and that was a old Nissan Pulsar. At the moment we have about 3 cars sitting out the front of my house including a VL Commodore, R31 Skyline (My baby) and a Mitsubishi Lancer CE. Apart from that we generally park our cars on our front lawn during the night time and keep the Lancer in the driveway so if we hear anything it is generally easy to run out the front and smash them over the head with a wrench. It's fairly good having parents that wake up over the tiniest of noises, :). But yeah i guess as long as you take your head unit with you every night when you go in or your head unit is the firmly locked in ones you should be ok, :).
If there been more than once, it could just be some punk kids that have parents with the same car?
if you cant leave your car in the garage, a cheap camera may be very useful if you think it will happen again.
"10-20 seconds with packing tape and you're in. Not hard really.
They were probably there for all of 1-2mins."
Yer people do this for a living an bring it to an art.
lol well our garage is small and is MY territory, my domain and im pretty much emptying it for the 260z i intend on buying
were gona soon have a
ba XR8 ute( dads baby),
my uncles freshly repaired merc,
mums territory
my dads merc 4x4( probably sold by then)
ASWELL as my hilux surf out the front( ill park it so it blocks the other cars)
all in a narrow drive way so if i do wake up the fronts full of cars and they might have a hard time getting out :)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
