Hey all,
Visiting surfers next week for work. Got a Free Sunday arvo and Monday day.
WTF should I get up to ?
Looking for car stuff mostly, hence on a car forum :).
Not so keen on the tourist stuff muesems, parks, zoo's etc.
I already found the local strip club so sorted there also hehe.
Sort of things like supercar hire, track days that are on even good workshops to check out ?
Don't mind the coast... as long as I'm there in someone else's car hahahahaha. Just head to the beach Monday, it'll be pretty empty...... if it's not raining.
lol a lot of help there !
I don;t have a car at moment but can arrange a hire one easy enough IF i find anything worth doing.
Last time in brissie I was over for Jambo, visited Mecury and a couple random importers.
Surely there is more to do ?
Sunday sess could be ok.
Though at this rate sounds like I'll be scaring the locals in my bathers during the day and then the strippers at night.
I highly recommend the latter, Butters :)
For me usually don't have much time outside of business up there, but definately hit up Broadbeach followed by Surfers (pref with a entourage..). Outisde of that I think theres a kart place at Southport, I been to before - had 125cc motor'd karts - was alright. Can't remember the name of them though :) . All the workshops you'll know already!
THEY sit around doing that all weekend.
Try checking inthemix.com.au to see if any music stuff is on if you are youngish and into nightlife.
Google helps re: track days
http://www.google.com.au/search?hl=en&...=cr%3DcountryAU
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
